Holybro Durandal only
  • SKU: MBS-ENTB-128
  • GTIN: 0658917504793
  • HAN: 11039
  • Category: Pixhawk
  • FC module
  • STM32H7 processor
  • Vibration damping and temperature protection
Holybro Durandal Flight Controller
The Holybro Durandal Flight Controller is a high-performance autopilot for drones, designed with a focus on powerful processing, stable sensors, and robust construction. It uses the STM32H7 processor and features a redundant IMU system, integrated vibration damping, and temperature protection for the sensors. This makes it particularly suitable for complex autonomous applications with demanding computational requirements.
Technical Data
  • Processors & Sensors:
    • Main FMU: STM32H743, 32-bit Arm® Cortex®‑M7, 480 MHz, 2 MB Flash, 1 MB RAM
    • IO Processor: STM32F100 / STM32F103 (32-bit Cortex-M3)
    • Integrated Sensors:
      • Accel/Gyro: ICM-20689 + optional BMI088 / ICM-20602
      • Magnetometer: IST8310
      • Barometer: MS5611
  • Electrical Specifications:
    • Maximum Input Voltage: 6 V
    • USB Power Supply: 4.75 – 5.25 V
    • Servo Rail Input: 0 – 36 V
    • Current Limiting: Telemetry port max. 1.5 A, other ports combined max. 1.5 A
  • Interfaces & I/O:
    • PWM Outputs: 13 (8 from IO processor, 5 from FMU)
    • 6 dedicated PWM / capture inputs on FMU
    • 5 serial ports (UART), some with flow control
    • 3 × I²C ports
    • 4 × SPI buses: internal high-speed sensor SPI, quiet SPI, barometer SPI, external SPI bus
    • Up to 2 × CAN buses for dual-CAN support
    • Analog inputs for voltage/current measurement from 2 batteries + 2 additional analog inputs
    • Receiver inputs: Spektrum / DSM, CPPM, S.Bus + analog/PWM RSSI
  • Mechanical & Temperature:
    • Dimensions: approx. 80 × 45 × 20.5 mm
    • Weight: approx. 68.8 g
    • Operating Temperature: up to approx. 85 °C
  • Special Features:
    • Vibration isolation to reduce high-frequency noise
    • Integrated heating elements for IMU temperature control
    • Dual power inputs for redundancy
  • Durandal Flight Controller (main board)
  • Cable set (for power, UART, PWM, etc.)
The Durandal supports common flight stacks such as PX4 and ArduPilot, making it suitable for both research and industrial drone applications.
Shipping weight: 0,40 kg
Item weight: 0,07 kg
€ 265,95
