Holybro Kakute F722 &Tekko32 F4 Metal 4in1 65A ESC Stack
- SKU: MBS-ENTB-107
- HAN: 20265
- Category: Development Boards
Manufacturers:
- The set consists of Kakute F722 and Tekko32 F4 Metal 4in1 65A ESC
Holybro Kakute F7 2.2 Flight Controller + Tekko32 F4 4-in-1 50A ESC – High-Performance Stack for FPV Drones
The Kakute F7 2.2 flight controller combined with the Tekko32 F4 4-in-1 50A ESC provides FPV pilots a compact, reliable, and high-performance foundation for racing and freestyle drones.
Main Features Kakute F7 2.2
- Powerful STM32F7 processor for fast flight calculations
- High-precision sensors for accurate stabilization and flight control
- Multiple UARTs and extensive connection options for peripherals
- Supports Betaflight, INAV, and other common flight firmware
- Compact and lightweight design (30.5 × 30.5 mm)
The Tekko32 F4 Metal 4-in-1 65A ESC is a compact and robust power ESC designed for high continuous currents and aggressive flight maneuvers. Metal casing, high-quality MOSFETs, and large capacitors ensure reliable power delivery even under heavy loads.
Key Features
- F4 MCU for fast ESC regulation and clean signal processing
- Continuous current up to 65A per channel with high burst reserves (depending on specification)
- Metal casing and large MOSFETs for excellent heat dissipation
- Large smoothing capacitors for stable voltage and minimal drops
- Supports common protocols: DShot (including 1200), MultiShot, OneShot, etc.
- 4-in-1 design saves space, weight, and reduces wiring complexity
Ideal for: high-performance FPV quads, long-range setups, heavy-lift configurations, and any build requiring high current reserves and reliable ESC performance.
