Holybro Pixhawk 6X Pro (FC only)
  • SKU: MBS-Z-298-01
  • GTIN: 0658917599669
  • HAN: 11070
  • Category: Pixhawk
  • Industrial IMU ADIS16470
  • New vibration isolation material with higher resonance frequency
  • Triple redundant IMU and double redundant barometer
  • STM32H753 processor
  • Modular flight controller with separate IMU, FMU and base systems
  • Independent power control for each sensor set through separate LDO
  • Ethernet interface
  • Temperature-controlled IMU board for optimum working conditions
Completely new vibration isolation design
The novel vibration isolation design utilizes durable silicone isolation material instead of conventional foam. Through extensive research, it offers optimal damping properties for IMUs with higher resonance frequencies, ideal for industrial and commercial drones.
The specifications for processors and sensors as well as the electrical and mechanical data of the flight control system are detailed:
 Processors
  • FMU Processor: STM32H753
  • 32-Bit Arm® Cortex®-M7
  • 480 MHz clock frequency
  • 2 MB Flash memory
  • 1 MB RAM
  • IO Processor: STM32F103
  • 32-Bit Arm® Cortex®-M3
  • 72 MHz clock frequency
  • 64 KB SRAM
Sensors
  • Acceleration/Gyro (1): ADIS16470
  • Range: ±40 g
  • Acceleration/Gyro (2): IIM-42652
  • Range: ±16 g
  • Acceleration/Gyro (3): ICM-45686 with BalancedGyro™ technology
  • Range: ±32g
  • Barometer (1): ICP20100
  • Barometer (2): BMP388
  • Magnetometer: BMM150
Electrical Data
  • Voltage Ratings:
    • Maximum input voltage: 6V
    • USB power input: 4.75–5.25 V
    • Servo rail input: 0~36V
  • Current Ratings:
    • Telem1 output current limiter: 1.5 A
    • All other ports combined output current limiter: 1.5 A
Mechanical Data
  • Dimensions:
    • Flight control module: 38.8 x 31.8 x 14.6 mm
    • Standard carrier board: 52.4 x 103.4 x 16.7 mm
    • Mini carrier board: 43.4 x 72.8 x 14.2 mm
  • Weight:
    • Flight control module: 23 g
    • Standard carrier board: 51 g
    • Mini carrier board: 26.5 g
Additional Information
  • Reference Links: Include links to test data, comparison tables, installation guides, and firmware support.
  • SKU 11070: Pixhawk 6X Pro Flight Controller Module
  • SKU 20260/20261: Pixhawk 6X Pro Flight Controller Module, Pixhawk Standard Carrier Board/Mini Carrier Board, PM02D HV Power Module, Cable Set
Note:
  • To make this product work, an FC module + a baseboard are required. An FC module or a baseboard alone will not work.
Pixhawk 6X Pro
€ 899,99
Docs MYBOTSHOP documentation
