Inventables X-Carve Upgrade Kits
X-Carve Upgrate Kit
  • Improved performance
  • 9mm 3GT belt
  • 212 oz-in NEMA 23 stepper motors for X and Y
  • With 50% more torque than standard Increase rack spacing from 2.5" to 4.5"
  • Increase the maximum width of the passing sheet from 34.75" to 37"
  • Increase milling volume -Installation time between 1 ½ hrs - 2 ½ hrs
The new upgrade kits by Inventables for your X-Carve, available on July 7th 2021:
X-Carve Upgrade: 9 mm Belt and Motor Kit
The new upgrade kits by Inventables for your X-Carve, available on July 7thIncrease your material removal rates, cutting speeds, and reliability
With this upgrade kit, your X-Carve is just 90 minutes away from higher material removal rates, cutting speeds, and reliability. Replaces the 6mm wide 2GT belts with 9mm wide 3GT belts and stepper motors with 50% more torque.
Includes
  • 1 x 9mm 3GT belting (3.5 meter)
  • 6 x 9mm belt clips (6) 9mm belt sleeves
  • 6 x 9mm wide belt idlers
  • 3 x 212 oz-in NEMA 23 stepper motors for X and Y with 50% more torque than stock
Installation Time: 90 min
X-Carve Upgrade: Z Axis Kit
Upgrade the rigidity, precision, and add 2" of gantry clearance of your X-Carve
Upgrade the rigidity, precision, and gantry clearance of your X-Carve with Z-axis and height improvements in this kit. With an additional 2 inches of Z-axis travel, this kit will nearly double the carvable volume of your X-Carve. Direct drive configuration eliminates drive belt and improves accuracy and reliability Reduce adjustments and maintenance Increases gantry clearance from 2.5” to 4.5” Increases maximum pass-through sheet width from 34.75” to 37”. Unique shape prevents potential interference with dust boot when machine is at XY home Keeps shavings within the work area of the machine
Includes
  • 4 x Direct Drive Z-Axis with upgraded 212 oz-in stepper motor (+50% torque) 2" Risers
  • 8 x Acrylic Dus Guards / Stiffeners
Installation Time: 60 minute
X-Carve Complete-Upgrade Kit
Makes your X-Carve faster, more rigid, and more accurate
Bundle and save with this ultimate X-Carve Upgrade Kit. Increase your X-Carve’s rigidity, torque, and material removal rate—3+ times faster—in just 2 1/2 hours. Reduce chatter and increase accuracy with these rock-solid upgrades to take your X-Carve to the next level. Nearly doubles the carvable work area of your X-Carve Increases gantry clearance from 2.5” to 4.5” Increases maximum pass-through sheet width from 34.75” to 37” Improve your material removal rate by 3x Upgrades motors for more than 50% more torque Replaces the 6mm wide 2GT belts with 9mm wide 3GT belts Improves accuracy and reliability Reduce adjustments and maintenance needs Unique shape prevents potential interference with dust boot when machine is at XY home Keeps shavings within the work area of the machine
Includes
  • 1 x Belt Upgrades 9mm 3GT belting (3.5 meters)
  • 6 x 9mm belt sleeves
  • 4 x Stepper Motor Upgrades 212 oz-in NEMA 23 stepper motors for 50% more torque
  • 4 x Z-Axis Upgrades Direct Drive Z Axis Upgrade 2” Risers
  • 8 x Acrylic dust guards
Installation time: Around 2 1/2 hours
Material Removal Rate Typically 3x improvement from stock X-Carve
NOTE: X-Carve Machines purchased 2015 or earlier will need updated X, Y1, Y2, and Z stepper motor cable assemblies.
Shipping weight: 3,00 kg
Item weight: 3,00 kg
Average item rating
Share your experiences with other customers!
All reviews:
How do reviews work?
Total entries: 1
Lohnenswertes Upgrade für die X Carve
5 from 5
Die Lieferunge erfolge schnell unkompliziert und sehr zufriedenstellend.
Die Montage benötigt seine Zeit, bei mir dauerte es etwas länger, da die Maschine schon 3 Jahre in betrieb war und dem entsprechen die ein oder andere Schraube verdreckt und fest war.
Nach der Montage lief die Maschine ruhiger und genauer,. Das höhere Drehmoment hilft bei den verschiedenen Schichten von Multiplexplatten und Leimholz.
Total entries: 1
Kits
from
€ 269,96
  • Available immediately
