Inventables X-Carve Upgrade: Z Axis Kit
  • SKU: MBS-IN-10-03
  • GTIN: 0096718606191
  • HAN: 30881-01
  • Category: Factory
X-Carve Upgrate Kit
  • Improved performance
  • Increase the maximum width of the passing sheet from 34.75" to 37"
  • Increase milling volume
  • Installation time 60 minutes
Upgrade the rigidity, precision, and add 2" of gantry clearance of your X-Carve
Upgrade the rigidity, precision, and gantry clearance of your X-Carve with Z-axis and height improvements in this kit. With an additional 2 inches of Z-axis travel, this kit will nearly double the carvable volume of your X-Carve. Direct drive configuration eliminates drive belt and improves accuracy and reliability Reduce adjustments and maintenance Increases gantry clearance from 2.5” to 4.5” Increases maximum pass-through sheet width from 34.75” to 37”. Unique shape prevents potential interference with dust boot when machine is at XY home Keeps shavings within the work area of the machine
Includes
  • 4 x Direct Drive Z-Axis with upgraded 212 oz-in stepper motor (+50% torque) 2" Risers
  • 8 x Acrylic Dust Guards / Stiffeners
Installation Time: 60 minute
NOTE: X-Carve Machines purchased 2015 or earlier will need updated X, Y1, Y2, and Z stepper motor cable assemblies.
Shipping weight: 6,00 kg
Item weight: 5,40 kg
Average item rating
Share your experiences with other customers!
All reviews:
How do reviews work?
Total entries: 1
Lohnenswertes Upgrade für die X Carve
5 from 5
Die Lieferunge erfolge schnell unkompliziert und sehr zufriedenstellend.
Die Montage benötigt seine Zeit, bei mir dauerte es etwas länger, da die Maschine schon 3 Jahre in betrieb war und dem entsprechen die ein oder andere Schraube verdreckt und fest war.
Nach der Montage lief die Maschine ruhiger und genauer,. Das höhere Drehmoment hilft bei den verschiedenen Schichten von Multiplexplatten und Leimholz.
Total entries: 1
Contact data
Kits
€ 519,95
  • Currently out of stock
