Lightware communication/power cable for SF20
  • SKU: MBS-Z-362
  • GTIN: 0658917505011
  • HAN: LA 000_184
  • Category: Accessories
  • compatible: SF20 series (SF20/C, SF20/HA), LW20/C
The LightWare LA 000_184 is the communication and power cable (400 mm) for the SF20 series. It is the standard connection cable for the SF20/C and comes pre-fitted on the LW20/C; LightWare and authorised distributors also stock it as a spare/accessory cable.
The cable carries the power supply, the communication signals and the servo driver signals, and connects to the sensor via an eight-position connector. It is shielded and should be earthed to reduce electromagnetic interference (EMI).
In combination with the LightWare DroneCAN adapter, the LA 000_184 serves as the matching connection cable between the adapter and the SF20 sensor.
Technical specifications
Type Communication and power cable
Length 400 mm
Compatible with SF20 series (SF20/C, SF20/HA), LW20/C
Connector (sensor side) 8-position, JST 08SUR-32S
Matching reciprocal (SMD/PCB) SM08B-SURS-TF
Transmitted signals power supply, communication signals, servo driver signals
Shielding shielded, to be earthed to reduce EMI
  • 1× LightWare LA 000_184 communication and power cable (400 mm) for SF20
Shipping weight: 0,10 kg
€ 17,99
