Luxonis DepthAI OAK-D-S2 POE Fixed Focus
Luxonis DepthAI OAK-D-S2 POE FF
  • 3D-Stereo Camera & OnBoard Image Processing
  • Based on Intel® Movidius™ Myriad™ X
  • 2 x 1280 x 800 Stereo Camera & 4K RGB Camera
  • First usage in < 30 Sekunden
  • USB-C Connection
The Luxonis DepthAI boards combine stereo or RGB cameras with the Intel® Movidius™ Myriad™ X platform. The result is a small board that can be used either stand-alone or with an additional device such as an NVIDIA Xavier Jetson, Raspberry Pi or many more. Due to the high performance Intel uC with a base clock of 700MHz this small & compact development board can calculate about 4.5 million possibilities in less than a second.
Differences between OAK-D & OAK-D-S2?
Improving the mechanical of OAK-D but without adding the cost of active depth (both in terms of $, and in terms of worse bright outdoor depth performance). Reuse all of OAK-D-PRO but no-populate the active illumination components, black out the glass where these would be, and use the existing OAK-D CCM. Make an existing passive-only OAK-D successor with the mechanical advantages. And offer fixed-focus RGB like OAK-D-Pro as well for better vibration handling.
What's the concept behind Luxonis?
The manufacturer wants to create a versatile platform with an extremely small form factor, on the basis of which anyone can execute a first basic script in less than 30 seconds. The development platforms are available in different configurations, such as with WLAN or a Raspberry PI Compute Module. If the first tests are promising, Luxonis also offers only the pure bare PCB's, which can be integrated as an OEM into a third party component.
What is DepthAI?
Every Luxonis development board is based on the DepthAI Firmware which has already the following features implemented:
  • Neural Inference (e.g. object detection, image classification, etc., including two-stage)
  • Stereo Depth (including median filtering)
  • 3D Object Localization (augmenting 2D object detectors with 3D position in meters)
  • Object Tracking (including in 3D space)
  • H.264 and H.265 Encoding (HEVC, 1080p & 4K Video)
  • JPEG Encoding
  • MJPEG Encoding
  • Warp/Dewarp
  • M12 X-Coded Ethernet, 802.3af PoE, 1 Gbps Ethernet
  • M8 connector with quite a bit of IO flexibility, including USB2 host
  • IP65 Sealed casing/protection
  • 4 TOPS of processing power (1.4 TOPS for AI)
  • Run any AI model, even custom architectured/built ones
  • Encoding: H.264, H.265, MJPEG - 4K/30FPS, 1080P/60FPS
  • Computer vision: warp/dewarp, resize, crop, edge detection, feature tracking
  • Stereo depth: perception at 120 FPS with filtering
  • Object tracking: 2D and 3D tracking
  • Dimensions: 111x40x31,3mm
  • Weight: 184g
  • Sensor: IMX378 (RGB Camera) | OV9282 (STereo Pair Camera)
  • FOV (D/H/V): 81°/69°/55° (RGB Camera) | 89,5°/80°/55° (Stereo Pair Camera)
  • Resolution: 12MP (4032 x 3040) (RGB Camera) | 1MP (1280 x 800) (Stereo Pair Camera)
  • Focus: AF: 50cm - infinity (RGB Camera) | FF: 19,6cm - infinity (Stereo Pair Camera)
  • Max. Framerate: 60fps (RGB Camera) | 120fps (Stereo Pair Camera)
  • OAK-D S2 PoE camera
  • M12 plug to RJ45 cable, 2m
  • Cleaning cloth
Shipping weight: 0,30 kg
Item weight: 0,18 kg
€ 574,95
