Luxonis DepthAI OAK-D-W IMX378 Wide Angle
  • Central RGB Camera Specifications: IMX378
  • 3D-Stereo Camera & OnBoard Image Processing
  • Based on Intel® Movidius™ Myriad™ X
  • 2 x 1280 x 720 Stereo Camera & 4K RGB Camera
  • First usage in < 30 Sekunden
  • USB-C Connection
The Luxonis DepthAI boards combine stereo or RGB cameras with the Intel® Movidius™ Myriad™ X platform. The result is a small board that can be used either stand-alone or with an additional device such as an NVIDIA Xavier Jetson, Raspberry Pi or many more. Due to the high performance Intel uC with a base clock of 700MHz this small & compact development board can calculate about 4.5 million possibilities in less than a second.
Differences between OAK-D & OAK-D-S2?
Improving the mechanical of OAK-D but without adding the cost of active depth (both in terms of $, and in terms of worse bright outdoor depth performance). Reuse all of OAK-D-PRO but no-populate the active illumination components, black out the glass where these would be, and use the existing OAK-D CCM. Make an existing passive-only OAK-D successor with the mechanical advantages. And offer fixed-focus RGB like OAK-D-Pro as well for better vibration handling.
What's the concept behind Luxonis?
The manufacturer wants to create a versatile platform with an extremely small form factor, on the basis of which anyone can execute a first basic script in less than 30 seconds. The development platforms are available in different configurations, such as with WLAN or a Raspberry PI Compute Module. If the first tests are promising, Luxonis also offers only the pure bare PCB's, which can be integrated as an OEM into a third party component.
What is DepthAI?
Every Luxonis development board is based on the DepthAI Firmware which has already the following features implemented:
  • Neural Inference (e.g. object detection, image classification, etc., including two-stage)
  • Stereo Depth (including median filtering)
  • 3D Object Localization (augmenting 2D object detectors with 3D position in meters)
  • Object Tracking (including in 3D space)
  • H.264 and H.265 Encoding (HEVC, 1080p & 4K Video)
  • JPEG Encoding
  • MJPEG Encoding
  • Warp/Dewarp
Technical Details:
  • 2 x OV9282 Stereo Camera @ 1280 x 720Px
  • 1 x IMX378 Fixed Focus Camera
  • 1 x IR Projector & IR LED (No- / Low Light Conditions)
  • Intel® Movidius™ Myriad™ X Platform
  • Intel Base frequency: 700MHz
  • Intel Lithography: 16nm
Delivery Content
  • 1 x Luxonis DepthAI OAK-D-S2
Shipping weight: 0,10 kg
Item weight: 0,09 kg
€ 476,95
