Luxonis OAK-D Long Range
  • Three stereo baselines of 5 cm, 10 cm, and 15 cm for depth sensing in the near to far range
  • Triple AR0234 2.3-megapixel global shutter color sensors, interchangeable M12-mount lenses
  • 4 TOPS of processing power (1.4 TOPS for AI)
  • USB 3.1 and RJ45 port with support for 802.af PoE
Thanks to its 15 cm baseline, the OAK-D LR enables precise depth sensing up to ~30 m.
It naturally includes all the features of the OAK-D series, the RVC2 core, and the ability to run any AI models.
The OAK-D LR is a Series 2 OAK camera offering 4 TOPS processing power and the ability to run any AI model. Thanks to the 15 cm wide baseline, this model is capable of further depth sensing (up to ~30 m). Users can easily swap lenses, and with very narrow FOV lenses, it's possible to achieve 100m+ of stereo depth perception.
Main Features:
  • 4 TOPS of processing power (1.4 TOPS for AI - RVC2 NN Performance)
  • Run any AI model, even custom architectured/built ones (models need to be converted)
  • Encoding: H.264, H.265, MJPEG - 4K/30FPS, 1080P/60FPS
  • Computer vision: warp (undistortion), resize, crop via ImageManip node, edge detection, feature tracking. You can also run custom CV functions
  • Stereo depth perception at 120 FPS with filtering
  • Object tracking: 2D and 3D tracking with ObjectTracker node
Specification:
  • OAK-SoM-Pro based
  • USB3.1 and 802.3at PoE
  • Triple AR0234 2.3MP global shutter color sensor
  • Camera Spacing {right} <-5cm-> {middle} <-10cm-> {left}
  • 3 stereo baselines: 5cm, 10cm, and 15cm for short, medium, and long-range depth
  • Swappable M12-mount lenses with M12 lock rings (to keep focus/alignment)
  • BNO086 IMU single chip 9 axis sensor with embedded sensor fusion
  • Aluminum Enclosure with Front Gorilla Glass
  • Rough dimensions: 202 x 43 x 40 mm (without rain cover)
  • Rain cover dimensions: 50 x 27 x 22 mm
  • 75mm Vesa mount M4 screws
  • 1/4" tripod mount in the center
  • Recovery button and RGB status LED on the bottom
  • Comes with the cables and rain cover, protecting the device from splashing water
  • We recommend using OAK Y-Adapter with USB-C Female -> USB-C Male extension cable if you are having powering issues.
Delivery Contents:
  • OAK-D LR Camera
  • Ethernet cable with RJ45 plugs, 2m
  • USB-CA-1m cable
  • 3x Locking rings
  • Lock ring fastening tool
  • Cleaning cloth
€ 904,95
