MAB AK60-6 v1.1 CubeMars T-Motor with MAB Controller
  • MAB Controller
  • KV80 or KV140
  • with planetary gearbox
AK60-6 V1.1 CubeMars – Compact BLDC Motor with Integrated Planetary Gearbox
The AK60-6 V1.1 from CubeMars combines high performance with a compact design in a brushless BLDC motor featuring a factory-integrated planetary gearbox. Thanks to its precise absolute encoder, integrated temperature sensor, and high torque output, it is especially well-suited for mobile and autonomous robotic applications.
Technical Data
  • Weight: 0.368 kg
  • Dimensions: Ø 79 × 39.5 mm
  • Encoder: Absolute encoder on the motor shaft (before reduction)
  • Reduction Ratio: 6:1
  • Gearbox Backlash: 9 arcmin (≈ 0.15°)
  • Sensors: Integrated temperature sensor
Variants
  • KV80: 3 Nm nominal, 9 Nm peak; max. 220 RPM at 24 V
  • KV140: 3 Nm nominal, 9 Nm peak; max. 400 RPM at 24 V
Applications
Ideal for demanding robotic applications, especially:
legged robots, exoskeletons, ROVs, UGVs, AGVs, drones, wheeled platforms, and collaborative robots (cobots).
Control System
  • MD80 by MAB Robotics
  • Reliable, user-friendly motor controller
  • Includes comprehensive technical documentation and support
Key Features of the MD80
  • Communication: CAN‑FD up to 8 Mbps or CANopen
  • FDCAN Termination: Software-controlled
  • Daisy-Chain: Stackable connectors
  • Auxiliary Ports: For external encoders, brakes, or limit switches
  • Setup: Plug-and-play with CANdle / CANdle HAT
  • ROS / ROS2 compatible
  • C++ and Python libraries available
Supported Control Modes
  • Position and velocity control (PID + motion profile)
  • Impedance control (PD)
  • Torque control (PI)
Encoder: Integrated 14-bit absolute encoder
Shipping weight: 0,50 kg
Item weight: 0,37 kg
KV
€ 588,95
  • Must be ordered. Ready for shipment in 8 days after order.
