MAB AK80-9 CubeMars T-Motor with MAB Controller
  • with MAB Controller
  • Integrated temperature sensor
  • BLDC motor
AK80-9 CubeMars – Compact BLDC Motor with Planetary Gearbox
The AK80-9 from CubeMars is a high-performance brushless BLDC motor with an integrated planetary gearbox. It delivers high torque, precise feedback, and built-in sensors, making it ideal for mobile and autonomous robotic systems.
  • Torque: 9 Nm (nominal), 18 Nm (peak)
  • Max Speed: 245 RPM at 24 V
  • Weight: 0.485 kg
  • Dimensions: Ø98 × 38.5 mm
  • Encoder: Absolute encoder on the motor side (before reduction)
  • Gear Ratio: 9:1
  • Backlash: 9 arcmin (≈ 0.15°)
  • Sensors: Integrated temperature sensor
Application Areas
Perfect for demanding robotics applications, especially mobile platforms such as:
legged robots, exoskeletons, ROVs, UGVs, AGVs, drones, wheeled robots, and collaborative robots (cobots).
MD80 Controller by MAB Robotics
  • Powerful and user-friendly motor controller
  • Includes full technical documentation and professional support
  • Key Features of the MD80:
  • Interfaces: CAN-FD up to 8 Mbps or CANopen
  • Software-controlled FDCAN termination
Daisy-chain compatible connectors
  • Auxiliary connectors for external encoders, brakes, or limit switches
  • Easy setup with CANdle / CANdle HAT
  • Plug-and-play with ROS / ROS2
  • Supported C++ and Python libraries
Supported Control Modes:
  • Position and velocity control (PID + motion profiles)
  • Impedance control (PD)
  • Torque control (PI)
  • Integrated 14-bit absolute encoder
Item weight: 0,49 kg
€ 839,95
