MAB Robotics MD80 V3.0 Motor Controller
  • Interface: CAN/FDCAN up to 8 Mbit/s
  • Up to 48V and 80A
  • Weight: only 15 g
MD80 v3.0 – Compact High-Performance Motor Controller for Brushless Drives by MAB Robotics
The MD80 v3.0 is specifically designed for mobile robotics applications, combining high performance, energy efficiency, and reliability in an extremely compact form factor. Whether for early-stage R&D prototypes or series production, this controller offers everything modern robotic systems require. During development, it integrates easily and quickly with the CANdle module, while in production it functions as a powerful, standalone control unit.
  • Input Voltage: up to 48 V DC
  • Max Motor Current (Peak): 80 A
  • Dimensions: Diameter 55 mm
  • Weight: only 15 g
  • Communication: FDCAN interface up to 8 Mbps
Expansion Ports
  • For on-/off-axis ring encoders
  • For brake systems or limit switches
  • Integrated Encoder: 14-bit absolute encoder onboard
Optional Features
  • Software-controlled FDCAN termination
  • RS422 communication interface
Motion Modes
  • Position & Velocity: PID control with motion profiles
  • Impedance Control: PD controller
  • Torque Control: PI controller
Key Highlights
  • Specially designed for mobile robotic systems such as:
    • legged robots, exoskeletons, ROVs, UGVs, AGVs, drones, cobots, wheeled platforms, and more
  • Quick setup with CANdle or CANdle HAT
  • Fully compatible with ROS / ROS2, including C++ and Python APIs
  • Compact & lightweight – ideal for space-constrained applications
Scope of Delivery
  • 1× MD80 Motor Controller
  • 1× Connection Cable
  • 1× Encoder Magnet
Shipping weight: 0,15 kg
Item weight: 0,02 kg
from
€ 274,95
  • Must be ordered. Ready for shipment in 7 days after order.
