Makera Spiral 'O' Single Flute Bit for Metal - 1/8 Shank
Makera Spiral 'O' Single Flute Bit for Metal - 1/8″ Shank
  • Shank Diameter: 3.175 mm
  • Total Length: ~ 38 mm
  • Contour cutting of sheets, plates, and blocks
  • Pocket milling
Product Description for Spiral 'O' Single Flute Bit for Metal - 1/8″ Shank
The Spiral 'O' Single Flute Bit offers superior chip evacuation and reduces the risk of chip re-cutting, ensuring a cleaner cut, even for non-ferrous metals like aluminum and brass.
Specifications:
Material: Solid Carbide
Applications:
Surface cleaning
Pocket milling
Hole boring
Materials:
Wood
Plastics
Composite materials
Non-ferrous metals
Tool Reference Parameters:
RPM: Spindle speed (RPM)
Feed: Feed rate (mm/min)
PFeed: Plunge feed rate (mm/min)
DOC: Depth of cut (mm)
Available Sizes:
  • 3.175 mm * 12 mm
  • 2.5 mm * 12 mm
  • 2 mm * 8 mm
  • 1.5 mm * 6 mm
  • 1 mm * 3 mm
Tool Table:
Tools Aluminum Brass Carbon Fiber Copper Hardwood PCB Plastic Softwood
1*3 mm Flat End (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.05
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.05
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
1.5*6 mm Flat End (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.05
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.05
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
2*8 mm Flat End (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.15
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 0.5
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
2.5*12 mm Flat End (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
3.175*12 mm Flat End (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
- RPM: 10000
Feed: 1000
PFeed: 300
DOC: 1
RPM: 10000
Feed: 1000
PFeed: 300
DOC: 2
  • 1x Spiral 'O' Single Flute Bit for Metal in the chosen size
Shipping weight: 0,10 kg
Item weight: 0,10 kg
Größe
from
€ 20,95
  • Available immediately
