MightyZAP 100N Ultra Force Version 12V PWM / TTL
  • SKU: MBS-ANT-46-02
  • GTIN: 0096718604791
  • HAN: L12-100PT-3
  • Category: Drive Technology
MightyZAP Linear Servomotor
  • Controllable via PWM / Half Duplex TTL
  • Coreless Motor
  • Ultra Force Version
  • 30mm Stroke
  • 100N
  • L12-100PT-3
The MightyZAP product line by iRROBOT consist of a variety of linear actuators that can work very precisely and can furthermore be controlled via PWM and Half Duplex TTL.
The positioning accuracy of 50 µm is realised by the integrated 32Bit micro controller, in combinaton with an 4096 step A/D Converter aswell as the mechanical design with low backlash. The casing consisting of industrial plastic combined with the other already mentioned components result in a very compact and reliable servo motor.
Key Features
  • Durable Coreless Motor
  • Built-in drive circuit for simplicity
  • High durability potentiometer
  • High Resolution -4096 step
  • Position control
Controlling
The MightyZAP 100N Ultra Force Version can be controlled via PWM Signals and also by an Half Duplex TTL interface. The MightyZAP is based on an 8Bit, 1 stop, No Party Structure aswell as the DYNAMIXEL servo motors. Please note that the feedback function can not be used when controlled via PWM signals. Through the feedback function the system/user is always capable of seeing the stroke length of each different cylinder. By allocating individual ID's there can be up to 254 linear servo motors be controlled and connected in series. Allocating individual ID's needs an exklusiv USB Adapter (IR-USB01). The required Tool can be downloaded for free.
Applications
The small dimesions, high repeatability and reliabiliy makes this linear servo motor a top product for a wide variety of applications as,
  • Reproducing  of production processes
  • UAV's / UGV's
Furthermore the MightyZAP Metal Bracket Set can be added as an  extra option.
Technical Data
  • Version: Ultra Force
  • Force: 100N
  • Speed: 7,7mm/s
  • Supply voltage: 12V
  • Gear: Industrial plastic
  • Engine: Coreless motor / 26W
  • Stroke length: 30mm
  • Positioning accuracy: 0,05mm
  • Operating temperature: -10°C - 60°C
  • Mechanical Backlash: 0,03mm
  • Controlling: PWM / Half Duplex TTL (8Bit, 1 Stop, No Parity)
  • PWM Puls width: minimum: 900µm | center: 1500 µm | maximum: 2100 µm
  • uC: 32Bit ARM
  • Protecton category: IP54
  • Dimensions: 57,4 x 29,9 x 15mm
  • 1 x MightyZAP 100N Servomotor 30mm PWM / TTL
  • Accessories
Shipping weight: 0,11 kg
Item weight: 0,06 kg
Supply Voltage
Interface
€ 202,95
