OpenMV CAN/RS232 Shield
  • SKU: MBS-SH-31
  • GTIN: 05390368407241
  • HAN: OMV-SHIELD-CAN-RS232
  • Category: Expansion Boards
  • RS and CAN operating in parallel
  • 0-5 V ADC input
  • Transient surge protection
The CAN/RS232 Shield expands the OpenMV Cam with simultaneous RS232 and CAN communication. RS232 supports data rates up to 1 Mb/s, while CAN-FD (on compatible models) reaches up to 8 Mb/s. Signals are routed to P4/P5 (RS232) and P1/P3 (CAN), with CAN-TX optionally switchable to P2. All interfaces can be fully isolated from the camera when required.
The wide-range 6–36 V power input includes reverse-polarity and transient protection and supplies the camera through a safe, back-feed–protected 5.4 V ORing topology.
Additionally, the shield provides a 0–5 V ADC input (scaled to 0–3.3 V, protected up to ±36 V) with an optional 240-Ω shunt for 4–20 mA signals, as well as a robust 0–5 V digital I/O port (SYN) featuring fault protection. By default, SYN operates as an open-drain trigger input on P10, but it can also function as a 0–5 V output or be fully isolated if needed.
The shield is compatible with all OpenMV Cam models and is ideally suited for modular embedded-vision and robotics applications.
Use Cases
The CAN/RS232 Shield is optimized for industrial and robotic environments that require deterministic communication architectures, robust power-input handling, and precise synchronous event control. Typical applications include robotics bus integration (CAN backbone), process and machine control, in-vehicle sensor data acquisition, real-time triggering of vision pipelines, and embedded autonomous systems operating on 12/24 V supply infrastructures.
Technical Specifications
  • PWR (6 V–36 V) – Reverse-voltage tolerant (down to –36 V), supplies VIN with 5.4 V, up to 600 mA output current
  • 0–5 V ADC input with reverse-voltage protection and built-in over-voltage clamping
  • 0–5 V digital input/output for camera synchronization, with integrated short-circuit protection
  • 8 Mb/s CAN-FD interface with filtering and switchable termination
  • 1 Mb/s RS232 interface with integrated filtering
  • All external interfaces include robust transient-voltage protection
  • Power consumption: 2 mA @ 3.3 V from the OpenMV Cam's 3.3 V rail
Scope of Delivery
  • OpenMV CAN/RS232 Shield
  • Standoffs and screws
  • Pin headers
Shipping weight: 0,20 kg
Item weight: 0,00 kg
€ 29,95
Docs MYBOTSHOP documentation
