Ouster LiDAR Rev8
  • SKU: MBS-SES-428
  • Category: LiDAR
The Ouster REV8 OS family is a generation of digital lidar sensors featuring – according to the manufacturer – the world's first native color capture (color and 3D data are fused directly in the silicon hardware). All variants share the same platform and differ primarily in field of view, range and resolution. The four REV8 versions compared:
Feature OSDome OS0 OS1 OS1 Max
Positioning Hemispherical; security, infrastructure Ultra-wide, short-range; robotics, warehousing, industrial Mid-range; security, infrastructure, AV Long-range; high-speed autonomy, heavy industry
Vertical field of view 180° 90° 45° 45°
Range @ 10 % target 20 m 35 m 90 m 200 m
Max. representable range ~250 m ~250 m ~250 m ~500 m
Channels 32 / 64 / 128 32 / 64 / 128 32 / 64 / 128 32 / 64 / 128 / 256
Vertical resolution (up to) 1.4° 0.7° 0.34° 0.17°
Precision (up to) ±0.5 cm ±0.25 cm ±0.25 cm ±0.25 cm
Weight 540 g 500 g 500 g 670 g
Power consumption 10–20 W 10–20 W 10–20 W 15–25 W
Operating temperature -40 to 60 °C -40 to 85 °C -40 to 85 °C -40 to 85 °C
Shared features of the REV8 platform
  • Native color capture (color + 3D fused in silicon)
  • Horizontal field of view 360°, horizontal angular resolution 0.09°, horizontal resolution up to 4,096
  • Up to 10,485,760 points/s, frame rate 5/10/15/20/30/40 Hz, 2 returns (strongest/second strongest)
  • Minimum range 0.0 m, embedded IMU, near-IR ambient data
  • Time synchronization gPTP / PTP / $GPRMC; Ethernet 1000BASE-T or 1000BASE-T1
  • Protection rating IP68 / IP69K, operating voltage 12 / 24 V
  • Engineered for functional safety: ASIL-B (ISO 26262), SIL-2 (IEC 61508), PLd (ISO 13849), cybersecure (ISO 21434)
Note: Range and resolution figures refer to the highest available configuration in each case. Ouster also offers the OS2 (long-range) in its lineup; the REV8 long-range variant referenced here is the OS1 Max. Availability of individual channel/beam configurations on request, per project.
PDF (4)
Datasheet OS1 MAX Rev8
Datasheet OS1 Rev8
Datasheet OS0 Rev8
Datasheet OSDome Rev8
Channels
Price on request
