Phidget Interface Kit 0/0/4
- SKU: MBS-Z-407
- GTIN: 0658917504762
- HAN: 1014_3
- Category: Phidgets
Manufacturers:
Phidget 0/0/4 interface kit
- up to 210 W DC or 1750 VA AC
- minimum required current 100 mA
The PhidgetInterfaceKit 0/0/4 allows you to control high-power devices such as light bulbs, fans, or pumps by electronically switching the power on and off.
The 1014 features 4 relay outputs capable of switching both AC and DC power. The relays are Single Pole Double Throw (SPDT) type.
- Switch up to four separate devices or circuits using SPDT relays
- Rated for up to 210 W DC or 1750 VA AC
- DC applications: switches circuits up to 30 V at 7 A
- AC applications: switches up to 12 A or 277 V AC (total power < 1750 VA)
- Mounting hardware included
Note: Not suitable for signal-level switching. At least 100 mA of current is required to break through the oxide layer on the relay contacts; most signal currents will not meet this requirement.
Technical Data
Board Properties
- Controlled by: VINT / USB (Mini-USB)
- USB Stack: PHIDUSB
- Driver support: Phidget22
- API object name: DigitalOutput
- Maximum VINT communication speed: 100 kbit/s
Physical Properties
- Switch type: SPDT
- Maximum switching speed: 20 cpm
- Recommended wire size: 12–24 AWG
- Operating temperature min: 0 °C
- Operating temperature max: 70 °C
Electrical Properties
- Dielectric strength: 1.5 kV AC
- Maximum contact resistance: 120 mΩ
- Max load voltage (DC): 30 V DC
- Max load voltage (AC): 277 V AC
- Minimum load current: 100 mA
- Max load current (DC): 7 A
- Max load current (AC): 12 A
- Max turn-on time: 18 ms
- Max turn-off time: 18 ms
- Minimum current consumption: 14 mA
- Maximum current consumption: 300 mA
- USB speed: Low Speed
