Phidget NEMA23 Brushless DC Motor - 4.3:1 Gearbox
- SKU: MBS-PHM-04
- GTIN: 05390368407173
- HAN: DCM4107_1
- Category: Brushless Motor & Actuator
Manufacturers:
- 24 V NEMA23 BLDC motor with 4.3:1 planetary gearbox
- 10.2 kg·cm torque at up to 930 rpm
- Integrated Hall sensors and 5 mm output shaft for encoders
Phidgets DCM4107_1 – NEMA23 Brushless DC Motor with 4.3:1 Planetary Gearbox
The DCM4107 is a 24 V brushless DC motor (BLDC) in NEMA23 format with 4 poles, delivering a torque of 10.2 kg·cm at speeds of up to 930 RPM.
Thanks to their built-in Hall-effect sensors, brushless DC motors allow convenient position and velocity control. They run quieter and last longer than comparable brushed motors. The attached planetary gearbox with a reduction ratio of approx. 4.3:1 provides higher torque at a correspondingly reduced speed.
- Rated torque of 10 kg-cm
- Speeds of up to 930 RPM
- Connects directly to a Phidgets BLDC motor controller
- Connector and wire ferrules on the cables for easy setup
- 5 mm rear shaft for mounting an optional encoder
- Built-in Hall-effect sensors for position and velocity control
Connection
This motor must be driven by a brushless DC motor controller that can both drive the three motor wires and read the Hall-effect feedback from the remaining five wires. Compatible controllers include the Phidgets DCC1100_1 (Brushless DC Motor Phidget, 20 A) and DCC1120_0 (30 V 50 A Brushless DC Motor Phidget).
Motor wire assignment: Terminal A = Red, Terminal B = Yellow, Terminal C = Black.
Note: Always disconnect the power supply of the motor controller before rewiring.
Technical Specifications
Motor Properties
- Motor type: Brushless DC motor
- Number of poles: 4
- Manufacturer part number: 56JXE300K(4.3)/57DMWH75-2440
- Mechanical output power: 115 W
- Rated torque: 10.2 kg·cm
- Rated speed: 930 RPM
Electrical Properties
- Rated current: 7 A
- Rated voltage: 24 V DC
- Coil resistance: 370 mΩ
Physical Properties
- Shaft diameter: 12 mm
- Keyway width: 4 mm
- Rear shaft diameter: 5 mm
- Mounting plate size: NEMA 23
- Operating temperature: -20 °C to +40 °C
Gearbox Properties
- Gearbox type: Planetary gearbox
- Gear ratio: 4 1/4 : 1
Scope of Delivery
- 1x Phidgets DCM4107_1 NEMA23 brushless DC motor with attached 4.3:1 planetary gearbox (connection cables with connector and wire ferrules)
