Phidgets 2x DC Motor
- SKU: MBS-M-34
- GTIN: 0658917504861
- HAN: DCC1003_0
- Category: Motordriver
Manufacturers:
- simultaneous control of two brushed DC motors
- connects via a VINT Hub Phidget
- continuous current of up to 4 A
The 2x DC Motor Phidget (DCC1003_0) is an easy-to-use DC motor driver for simultaneously controlling two brushed DC motors. It connects via a VINT Hub Phidget and delivers up to 4 A of continuous current per motor at a supply voltage of 8–30 V DC. Speed (forward and reverse) as well as acceleration are fully controllable in software via the Phidget22 API.
The DCC1003 features built-in galvanic isolation (isolation voltage 3.8 kV DC) for enhanced system reliability, as well as overcurrent protection, polarity protection, and a standard failsafe mode. The ultrasonic PWM frequency of 25 kHz ensures quiet operation. For most applications, a Power Guard Phidget is additionally recommended to protect the power supply against back-EMF voltage spikes generated during braking or direction changes.
Key Features
- Controls 2 brushed DC motors with up to 4 A continuous current each
- Built-in galvanic isolation (3.8 kV DC) for enhanced system reliability
- Ultrasonic PWM frequency 25 kHz for quiet operation
- Protection features: overcurrent protection, polarity protection, failsafe mode
- Connects via VINT Hub (Phidget cable), compatible with Phidget22 driver
- Software control of speed and acceleration via DCMotor API
- Supported programming languages: C, C#, Python, Java, JavaScript, Swift, LabVIEW, Max
- Supported operating systems: Windows, macOS, Linux, iOS, Android
| DCC1003_0 – Technical Specifications | |
| Board Properties | |
| Controlled By | VINT (Phidget cable) |
| Driver Support | Phidget22 |
| VINT Communication Speed Max | 10 kbit/s |
| Controller Properties | |
| Motor Type | DC Motor (brushed) |
| Number of Motor Ports | 2 |
| Acceleration Min | 0.1 Duty Cycle/s |
| Acceleration Max | 100 Duty Cycle/s |
| PWM Frequency | 25 kHz |
| Sampling Interval Min | 100 ms/sample |
| Sampling Interval Max | 60 s/sample |
| Acceleration Resolution | 0.1 Duty Cycle/s |
| Velocity Resolution | 0.001 Duty Cycle |
| Current Limit Resolution | 5.6 mA |
| Acceleration Time Min | 20 ms |
| Acceleration Time Max | 20 s |
| Electrical Properties | |
| Continuous Motor Current Max (per motor) | 4 A |
| Supply Voltage Min | 8 V DC |
| Supply Voltage Max | 30 V DC |
| Current Consumption Unconfigured (VINT Port) | 500 µA |
| Current Consumption Max (VINT Port) | 750 µA |
| Replacement Fuse | 10 A Slow Blow Blade Type, Standard or Micro |
| Isolation Voltage (DC) | 3.8 kV DC |
| Physical Properties | |
| Recommended Wire Size | 16 – 26 AWG |
| Operating Temperature Min | -40 °C |
| Operating Temperature Max | 85 °C |
| Country of Origin | CN (China) |
Scope of Delivery
- 1× 2x DC Motor Phidget (DCC1003_0)
Note: Operation requires a VINT Hub Phidget (e.g. HUB0001_0, HUB0002_0 or HUB5000_0) and a Phidget cable. For most applications, a Power Guard Phidget (e.g. SAF2000_0) is also recommended to protect the power supply against back-EMF voltage spikes. All additional components are sold separately.
