Phidgets Weighing Scale Kit
  • SKU: MBS-Z1-250
  • GTIN: 0658917504939
  • HAN: KIT4007_0
  • Category: Accessories
  • Compact weighing system kit with aluminum housing
  • Three interchangeable micro load cells (780 g, 5 kg, 25 kg)
The Weighing Scale Kit is a compact, easy-to-assemble weighing system with an anodized aluminium frame and three interchangeable micro load cells (780 g, 5 kg, 25 kg). The top and bottom plates of the aluminium frame are mounted at either end of the load cell; a load placed on the surface creates a shear force in the cell, and the measured value is proportional to the weight of the object. After a simple two-point calibration, accurate weight measurements can be calculated.
The load cells are read via a bridge interface (e.g. PhidgetBridge 4-Input or Wheatstone Bridge Phidget). Two known reference weights are sufficient for calibration; the linear output of the cells allows straightforward mathematical conversion into grams or other units.
Note: The 780 g cell has thin joints at its ends and is vulnerable to damage if loaded above 780 g. For applications where the weight range is uncertain, the 5 kg cell is recommended.
Key Features
  • Easy-to-assemble weighing scale with anodized aluminium frame
  • 3 interchangeable load cells included: 780 g, 5 kg, 25 kg
  • Compatible with all Phidget bridge interfaces
  • Linear output – simple calibration with two reference weights
  • Dimensions: 156 × 156 mm
Technical Specifications
Frame (KIT4007_0)
Material Aluminium, anodized
Length 156 mm
Width 156 mm
Accuracy Class Consumer Grade
Load Cell FRC4114_0 – 780 g
Weight Capacity Max 780 g
Maximum Overload 936 g
Creep 7.8 g/hr
Zero Balance ± 78 g
Cell Repeatability Error Max ± 390 mg
Cell Non-Linearity Max 390 mg
Cell Hysteresis Max 390 mg
Temperature Effect on Span 39 mg/°C
Temperature Effect on Zero 39 mg/°C
Rated Output 1 mV/V
Output Impedance 1 kΩ
Supply Voltage Max 10 V DC
Operating Temperature −10 to +40 °C
Cable Length 200 mm
Material Aluminium Alloy
Screw Thread Size M4
Load Cell FRC4115_0 – 5 kg
Weight Capacity Max 5 kg
Creep 50 g/hr
Zero Balance ± 500 g
Cell Repeatability Error Max ± 2.5 g
Cell Non-Linearity Max 2.5 g
Cell Hysteresis Max 2.5 g
Load Cell FRC4116_0 – 25 kg
Weight Capacity Max 25 kg
Creep 250 g/hr
Zero Balance ± 2.5 kg
Cell Repeatability Error Max ± 12.5 g
Cell Non-Linearity Max 12.5 g
Cell Hysteresis Max 12.5 g
Customs Information
Country of Origin CN (China)
Canadian HS Export Code 8423.90.00
American HTS Import Code 8423.90.10.00
Scope of Delivery
  • 1 × Aluminium frame KIT4007_0 (top and bottom plate, anodized)
  • 1 × Micro load cell FRC4114_0 (780 g)
  • 1 × Micro load cell FRC4115_0 (5 kg)
  • 1 × Micro load cell FRC4116_0 (25 kg)
  • Not included: bridge interface (e.g. DAQ1500_0 or 1046_1), USB cable, Phidget cable
€ 49,95
