ROBOTIQ 2-Finger Gripper 85 & 140mm Basic Gripper Unit 85mm / 3.3 in
- SKU: MBS-Z1-04-05
- GTIN: 0618455046469
- HAN: AGC-GRP-2F85
- Category: Gripper
Manufacturers:
Robotiq 2-Finger Gripper
- Gripper range depends on the version: 0-85mm / 0-140mm
- Gripping Force: 2F85 20-235N / 2F140 10-125N
- Closing Speed: 2F85 20-150mm/s / 2F140 30-250mm/s
- Weight: 2F85 900g. / 2F140 1000g
Special prices for Universities & Research Institutes! Prices have VAT included.
General
ROBOTIQ is a very successful company that is working in the field of automatization. The team of highly qualified engineers develop, in close collaboration with Universal Robots, easy implementable gripper, torque-momentum sensoric aswell as camera modules used for Machine Vision. Both versions of the ROBOTIQ 2-Finger (2F85 / 2F140) have a very light weight design but also a very high force between 125 / 235N. Even heavy objects up to 5KG can be gripped and moved without any problem. The funcitonality and the fast control speed result in the ROBOTIQ 2-Finger gripper beeing a very efficient gripper that is worth its price.
Following there are is some of the most important technical data of the 2F85 and 2F140 2-Finger gripper listed. The full data sheet can be found HERE.
Example of application
Following there are shown to examples of application. The left picture shows the 2F85 beeing used for quality check. The right picture shows a Pick&Place automatization to further process PCB's. Due to the easy configuration of the gripper force there is no danger of damaging the objects.
Delivery content
- 1 x 2F-85 Basic Gripper Unit
- 2 x Flat Silicone Fingertips
- 1 x Parallel mechanism locking pins
- 1 x Screw kit
| Item information | Value |
| Shipping weight: | 1,50 kg |
| Item weight: | 0,93 kg |
