Raph Rover (UGV platform)
  • Based on ROS 2
  • Aluminum housing
  • All the wheels are fitted with motors – the rear wheels are steerable
The Raph Rover is a fully integrated, ROS 2-based research and development platform, designed so that users can concentrate on algorithms and innovation — without having to build the hardware from scratch.
It features a rugged aluminium housing, a large mounting plate and pre-installed sensors, so that it can be used out of the box and is built for real-world research and development environments.
The platform supports modular extensions – your own sensors, grippers or cameras can be integrated easily.
All wheels are driven by their own motors, with the rear wheels additionally steerable. This results in high manoeuvrability combined with good traction.
Technical Data
Parameter Value
Dimensions (L×W×H) 559 mm × 474 mm × 255 mm
Weight 12.5 kg
Maximum payload 10 kg
Maximum linear speed 1.8 m/s
Maximum angular speed 4.7 rad/s
Ingress protection IP 54
Operating temperature –10 °C to +40 °C
Runtime up to 4 hours (with two batteries)
Connection range up to 100 m
Ground clearance 80 mm
Track width 385 mm
Wheelbase 382 mm
Drive & Structure
  • All wheels driven, rear wheels independently steerable – high agility with full traction.
  • Complete on-board electronics: SBC (single board computer) „UPBoard 7000“ (Intel® N100) and „RaphCore“ controller.
  • Mounting plate with a hole pattern (25 mm / 5.4 mm) for straightforward expansion.
Battery & Power Supply
  • Li-ion battery pack 6S (22.2 V) with approx. 4 Ah (≈ 88.8 Wh) per pack.
  • Hot-swappable battery system (can be exchanged during operation).
  • Maximum output power of the battery pack approx. 650 W.
Interfaces & Power for External Devices
  • USB A, USB C, HDMI and RJ-45 Ethernet interfaces.
  • Power supply for external devices: 5 V / 12 V / BAT (18-25 V) outputs available.
  • Mounting plate: 330 mm × 198 mm × 2 mm, hole pattern 25 mm × 25 mm, hole diameter 5.4 mm (for M5 screws).
Sensors & Perception
  • Stereo camera (e.g. OAK-D Pro W) with wide-angle lens, colour and stereo depth.
  • 360° 2D LiDAR scanner with a range of up to 40 m, scan rate approx. 32,000 points/s.
Software & Control
  • Operating system: Ubuntu with ROS 2 support.
  • Web-based GUI for teleoperation and live video streaming.
  • Full access via ROS 2 topics, services and actions.
Scope of Delivery
  • 1 × Raph Rover platform (pre-assembled)
  • 2 × Battery packs (6S li-ion)
  • 1 × Charger (li-ion charger)
  • 1 × Set of tools (assembly accessories)
Note: A complete official list of accessories (e.g. remote control, cable set, additional sensors) is not itemised.
Shipping weight: 15,00 kg
Item weight: 12,50 kg
Others (1)
Fictionlab Raph Rover Docs
€ 15.414,95
