Robotiq Force Torque Sensor FT300-S (IP65)
  • SKU: MBS-Z1-07
  • GTIN: 0618455046377
  • HAN: FTS-300-S-UR-KIT / 41939
  • Category: Sensors
  • Measuring range: Fx,Fy,Fz: up to 300N | Mx,My,Mz: up to 30Nm
  • Signal noise: Force: 0,5-1,2N | Moment: 0,02-0,03Nm
  • Data output rate: 100Hz
  • working temperature: 15°C - 35°C
Special prices for Universities & Research institutes! All prices have VAT included.
The Robotiq FT 300-S (successor to the FT-300) is a 6-axis force-torque sensor that enables robots to perform force-controlled and contact-intensive tasks. It precisely detects and measures contact forces and torques, thereby improving robot control and simplifying programming.
Thanks to plug-&-play integration and the included Force Copilot software, force-sensitive tasks can be set up even without programming knowledge. Typical applications include assembly and insertion, pick-&-place, surface finishing, quality testing, machine tending, and hand-guided teaching of motion paths.
The stiff metal construction and the wear-free, contactless sensing technology ensure high accuracy and repeatability – over the entire product life no calibration is required. With IP65 protection, the sensor is also suitable for environments with dust, debris or water.
The FT 300-S is compatible with Universal Robots (CB series), Omron TM and Techman Robot; a Development Package for Linux and Windows is available for custom development.
Axes 6 (Fx, Fy, Fz / Mx, My, Mz)
Measuring range ±300 N (Fx, Fy, Fz) / ±30 Nm (Mx, My, Mz)
Overload capacity 500 %
Weight 0.44 kg
Data output rate 100 Hz
External noise immunity immune
Ingress protection IP65
Operating temperature 5 to 40 °C
Communication Modbus RTU (RS485)
Sensing technology wear-free/contactless, calibration-free over the product life
Compatibility Universal Robots (CB series), Omron TM, Techman Robot
Software Force Copilot (incl.); Development Package for Linux/Windows
  • 1× Robotiq FT 300-S force-torque sensor
  • Mechanical coupling / mounting hardware
  • Connection/communication cable
  • Force Copilot software (provided as download)
Note: The exact scope of delivery (e.g. robot-specific coupling, cabling and controller connection) depends on the selected robot kit – please specify the target robot system when ordering.
Item weight: 0,44 kg
€ 5.712,00
Docs MYBOTSHOP documentation
