SIYI E6 Propulsion System
  • 6 kg thrust per rotor
  • Efficiency up to 7.0 g/W
  • Drone applications
E6 Propulsion System – Power Meets Precision
The E6 is a high-performance, integrated propulsion system independently developed by SIYI Technology, specifically designed for drone platforms with a thrust range of 3 to 6 kg per rotor. With precise control and outstanding reliability, the E6 utilizes FOC vector control, dual throttle redundancy, a modular structure, potted and sealed components, intelligent data monitoring, error logging, and IPX6 protection. It is the ideal solution for industrial and agricultural drone applications.
Key Features
  • Modular design
    • Maximum compatibility and simple integration
  • High-efficiency centrifugal fan
    • For effective and rapid heat dissipation
  • Integrated ESC with protection Features
    • Maximum safety and stability
  • Extremely reliable
    • Over 1000 hours of continuous operation in lab tests
  • Long-term stability
    • Tested with over 200 hours of flight time
  • FOC-ESC for precision Control
    • Responsive, quiet, efficient, and stable
  • Real-time feedback & error logging
    • For intelligent system diagnostics
  • PWM & CAN interfaces
    • With redundant throttle control
  • Wide system compatibility
    • Supports ArduPilot, PX4 Autopilot, and DroneCAN
Powerful Thrust – Effortless Control
With a recommended maximum thrust of 6 kg per rotor and up to 7.0 g/W efficiency, the E6 enables powerful yet energy-efficient flight.
Thanks to its dual redundancy, the system is especially reliable when carrying payloads and allows longer flight times with higher operational efficiency.
Compared to similar E-series Systems:
  • +5.9% maximum thrust per rotor
  • +9.0% recommended maximum thrust
  • +50% improved ESC overcurrent capacity (with optimal cooling)
Optimized Propellers – Where Efficiency Meets Performance
The specially designed propellers with a large pitch angle and refined aerodynamics deliver high thrust while optimizing energy efficiency.
Made from carbon-fiber-reinforced nylon composite, they are exceptionally durable, corrosion-resistant, and low-maintenance.
FOC-ESC – Precision Flight Control
The electronic speed controller is based on FOC vector control, ensuring ultra-precise, quiet, and stable control – ideal for sensitive applications and professional use.
Modular & Ready-to-Use
The E6 system requires no additional assembly of individual components – it mounts directly onto the drone arm.
Pre-assembled, ready to use, and extremely maintenance-friendly.
Universal Voltage Platform
Compatible with operating voltages up to 63V, the E6 system supports a wide range of 12–14S LiHV batteries, making it highly adaptable to different operating conditions and power supply Systems.
Overall
  • Product Weight: 825g (with propellers)
  • Voltage Platform: 12-14S (LiPo)
  • Mounting Tube Diameter: Φ30mm
  • Signal Support: CAN/PWM (Compatible with 5V/3.3V)
  • Throttle Pulse Width: 1050-1950us (Fixed throttle)
  • Operating Temperature: -20~50℃
  • Protection Rating: IPX6
  • Maximum Thrust (Single-axis): Maximum thrust 12.5kg (at sea level)
  • Recommended Thrust (Single-axis): Recommended takeoff weight 3-6kg (at sea Level)
ESC
  • Overcurrent Capability: 120A peak, maximum continuous current 70A
  • Maximum Operating Voltage: 63V
  • Communication Protocol: CAN
Motor
  • Motor Stator Size: 62*18mm
  • KV: 155KV
Propeller (foldable)
  • Diameter * Pitch: 24*9.0
  • Material: Carbon fiber nylon composite
  • Weight: 109.6g
  • Foldable/Direct Propeller: Foldable propeller
E6 Foldable Propeller Performance
Shipping weight: 1,00 kg
Item weight: 0,72 kg
€ 1.079,95
