SoftGripping control box with integrated pump
  • SKU: MBS-SG-01
  • GTIN: 0618455053405
  • HAN: SG.BP.1P.C1
  • Category: Gripper
  • for cobot and training applications
  • Diameter of tubing: 6mm
  • -0.5 to 2.0 bar
  • Compressor and vacuum pump permanently installed
The perfect control box for cobot and training applications. But also mobile applications where an external or large compressor is inaccessible are perfect uses for this control box. It contains everything needed to operate pneumatic grippers: a compressor and a vacuum pump are permanently installed. The grippers are very robust and can be operated at a speed of over 60 cycles per minute without any problems. Basically, the use of this box allows the operation of the following SoftGripping product lines: Educational, SoftActuator and SoftGripper, but is also applicable to other product lines.
On the front side, the current pressure can be read in the pressure display and adjusted via a rotary knob. The pressure output and signal input are located on the rear of the unit. The signal input controls the position of the fingers. You can switch between 3 positions: Grip, Open and Release.
  • Outer diameter of the hoses: 6mm
  • Pressure range finger outlet: -0,5 to 2,0 bar
  • SoftGripping control box with integrated pump
Operation Instructions SoftGripping Controlbox with pump
€ 1.412,95
