Sonair ADAR One
- SKU: MBS-SES-439
- GTIN: 05390368407166
- Category: 3D Machine Vision
Manufacturers:
Sonair ADAR One
- IP64
- Field of view: 180° × 180°
- ROS 2 compatible
Sonair ADAR One – safety-certified 3D ultrasonic sensor
According to the manufacturer, the ADAR One is the world’s first safety-certified 3D ultrasonic sensor for human-robot collaboration. Instead of scanning a single plane like a conventional safety laser scanner, it monitors a complete volume of 180° × 180° at ranges up to 4 m – including everything above, below and in between the conventional scan plane.
It is based on PMUTs, piezoelectric ultrasonic transducers in MEMS technology, combined with digital beamforming on a quad-core ARM SoC. Because the sensor works with sound instead of light, it also functions in darkness, dust and backlight and detects glass as well as reflective and low-contrast surfaces where optical sensors fail. There are no moving parts: the ultrasonic array is fixed.
Your advantages at a glance
- Certified safety: SIL 2 to IEC 61508 and PL d to EN ISO 13849, EC type-examination certificate from exida
- Volume instead of plane: the 180° × 180° field of view also captures low and overhanging obstacles
- Independent of light: reliable in darkness, dust and backlight as well as on glass and reflective surfaces
- 128 zone presets: three simultaneously monitored zones per preset, switchable via eleven safe inputs
- Compact and efficient: 104 × 54 × 25 mm, 200 g, maximum 5 W
- Several sensors side by side: no crosstalk where detection ranges overlap
- ROS 2-ready: 3D point cloud over Ethernet in addition to the safe OSSD output
| Field of view | 180° × 180° |
| Detection range | 0–4 m; 0–5 cm obstacle detected, position not reported |
| Range precision | 2–10 cm |
| Angular precision | 0–45°: approx. 3° · 45–70°: approx. 6° · 70–90°: over 10° |
| Detection capability (safety function) | Torso (≥ Ø155 mm): 0–3 m at 0–75°, 0–2 m at 0–80° Legs (≥ Ø70 mm): 0–2.5 m at 0–60°, 0–1.5 m at 0–80° Cylinder, acoustically hard (≥ Ø30 mm): 0–3 m at 0–60°, 0–1.5 m at 0–80° |
| Response time | min. 112 ms |
| Frame rate | max. 18 Hz |
| Ultrasonic frequency | 65–85 kHz |
| Zones | 3 simultaneously (1 protective zone, 2 warning zones) per preset, 128 presets |
| Safe outputs | 1× OSSD pair (protective zone), 2× status output (inner and outer warning zone) |
| Safe inputs | 11 static control inputs for zone selection |
| Data interface | Ethernet (CoAP over UDP/IP) for 3D point cloud and configuration |
| Indicators | 2 dual-colour LEDs for OSSD and system status |
| Power supply | 24 V DC (18–28 V, SELV/PELV), max. 5 W |
| Dimensions / weight | 104 × 54 × 25 mm (W × H × D), 200 g |
| Ingress protection | IP64 |
| Operating temperature | 0 to +50 °C |
| Safety parameters | SIL 2 (IEC 61508), PL d (EN ISO 13849), PFH below 1.5 × 10⁻⁷/h; assessed to IEC 61496 with adaptations for ultrasound |
Typical applications
- Autonomous mobile robots in warehousing, production, logistics, retail and hospitals
- Machine safety at robot cells, palletisers, CNC machine tending and packaging lines
- Redundant safety layer alongside LiDAR and cameras – sound instead of light closes perception gaps
- Adding vertical awareness and close-range detection
- Compact robot platforms with limited space and energy budget
- 1× Sonair ADAR One
