Stereolabs Robotics Perception Kit - Dual
  • SKU: MBS-SES-351
  • Category: Sensors
  • with or without a polariser
  • Lens focal length: 2.2 mm / 4 mm
  • GMSL2 Capture Card Duo, integrated
Stereolabs Robotics Perception Kit – Dual: complete stereo vision package with NVIDIA Jetson AGX Orin
The Robotics Perception Kit – Dual is a rugged all-in-one package for 3D perception and spatial AI in autonomous robotics. It combines two ZED X stereo cameras with an NVIDIA Jetson AGX Orin 64 GB Developer Kit, housed with an integrated GMSL2 capture card in a robust aluminum enclosure. This gives robots high-resolution surround perception for navigation, obstacle detection and localization.
The ZED X cameras feature dual global shutter color sensors (1920 × 1200), a high-performance IMU and Stereolabs Neural Depth. Images are transmitted to the computer over the interference-free GMSL2 link with low latency at distances of up to 15 m, and the cameras can be hardware-synchronized at frame level. With the ZED SDK, point clouds and odometry from both cameras are fused into a single data source. Thanks to their IP67 enclosure, the cameras are also suitable for outdoor use.
Configuration options
Option Choice Recommendation
Polarizing filter without / with polarizer without: indoor use without reflective surfaces · with: outdoor use, reduces glare and reflections
Lens focal length 2.2 mm / 4 mm 2.2 mm: very wide field of view with optically corrected distortion · 4 mm: higher resolution and depth accuracy at longer range
GMSL2 extension cable length 0.5 / 1.5 / 5 / 10 / 15 m depending on the distance between cameras and computer
Kit
Computer NVIDIA Jetson AGX Orin 64 GB Developer Kit
Capture card GMSL2 Capture Card Duo, integrated
Enclosure Robust aluminum enclosure for the AGX Orin Developer Kit
Cameras 2× ZED X stereo camera
Camera connection GMSL2, cable length up to 15 m
Synchronization Frame-level hardware synchronization within 100 µs
Software ZED SDK, ZED X drivers
ZED X stereo camera
Image sensors 2× global shutter, color
Resolution 1920 × 1200 per sensor (video and depth)
Frame rate 60 fps at 1920 × 1200 · 120 fps at 960 × 600
Pixel size 3 µm
Stereo baseline 120 mm
Lens 9-element glass lens, 2.2 mm or 4 mm focal length
Depth sensing Neural Depth Engine, from 10 cm to tens of meters
IMU 16-bit triaxial accelerometer and gyroscope
Interface GMSL2 with external synchronization
Enclosure Aluminum, 160 mm
Protection rating IP67
Operating temperature approx. −20 to +54 °C (−5 to 130 °F)
  • 2× ZED X stereo camera (with selected lens and polarizer option)
  • 1× NVIDIA Jetson AGX Orin 64 GB Developer Kit
  • 1× GMSL2 Capture Card Duo
  • 1× aluminum enclosure for the AGX Orin Developer Kit
  • 1× GMSL2 1-to-4 cable (M-F)
  • 2× GMSL2 extension cable (M-F) in the selected length
Notes
  • The NVIDIA Jetson AGX Orin Developer Kit is only available individually – one kit can be purchased per order.
  • The selected cable length applies to both extension cables.
Polarizer
ZED X (Lens Focal Length)
GMSL2 Fakra Cable M-F Langth
Price on request
  • Available immediately
