Stereolabs ZED Box 2 Max - T4000
  • up to 1,200 FP4 TFLOPS
  • including accessories
  • 64 GB LPDDR5X with 273 GB/s memory bandwidth
The Stereolabs ZED Box 2 Max – T4000 is an industrial physical AI computer for demanding robotics – from humanoids to advanced autonomous machines. With the NVIDIA Jetson AGX Thor T4000, 64 GB of LPDDR5X memory and up to 1,200 FP4 TFLOPS, it runs multi-camera perception, sensor fusion and large AI models such as vision-language-action (VLA) models simultaneously, directly on the robot.
Eight GMSL2 inputs (FAKRA-Z) capture up to eight ZED X stereo or mono cameras on a shared hardware clock. For connecting LiDAR, network cameras and other sensors, it offers a QSFP+ port with 3 × 10 GbE, two Gigabit ports, Wi-Fi 6 and optionally four PoE+ ports. The ZED Box 2 Max is also optionally available with an integrated RTK-capable GNSS receiver.
The actively cooled aluminum enclosure is built for industrial use – with a wide 9–36 V input range and protection against transients, reverse polarity and ESD. The ZED SDK comes preinstalled, and ROS 2 and Isaac ROS are supported.
Ideal for:
  • Humanoid robots and mobile manipulators
  • Running large AI models (VLA, LLM) alongside perception
  • 360° perception with up to eight synchronized cameras
  • Fusion of camera, LiDAR and GNSS in autonomous machines
  • Outdoor robotics with precise RTK positioning (GNSS variant)
Key Benefits
  • NVIDIA Jetson AGX Thor T4000 with up to 1,200 FP4 TFLOPS
  • 8 × GMSL2 for hardware-synchronized multi-camera systems
  • QSFP+ with 3 × 10 GbE, 2 × GbE, optional 4 × PoE+
  • Optional RTK GNSS (L1/L2/L5) and slots for 4G/5G
  • Wide 9–36 V input range with reverse polarity and ESD protection
  • ZED SDK preinstalled, support for ROS 2 and Isaac ROS
  • Power supply, GMSL2 cables and antennas included
The ideal choice for anyone who wants to run perception, sensor fusion and large AI models on a single platform directly on the robot.
Technical Specifications
Computing
Module NVIDIA Jetson AGX Thor T4000
AI performance up to 1,200 FP4 TFLOPS
GPU 1536-core NVIDIA Blackwell, 5th-gen Tensor Cores, MIG
CPU 12-core Arm Neoverse-V3AE, 2.6 GHz
Memory 64 GB LPDDR5X, 256-bit, 273 GB/s
Storage M.2 NVMe SSD, 256 GB, 1 TB or 2 TB
Video Encoding e.g. 6 × 4Kp60 H.265, decoding e.g. 4 × 8Kp30 H.265
Cameras
Camera inputs 8 × GMSL2 (FAKRA-Z), hardware-synchronized
Compatible cameras ZED X stereo and mono cameras (configuration depends on resolution, frame rate and bandwidth)
Networking and Communication
Ethernet 1 × QSFP+ (3 × 10 GbE), 2 × GbE RJ-45
PoE+ (optional) 4 × GbE PoE+, 25 W per port
Wireless Wi-Fi 6 (2.4/5 GHz)
Cellular 2 × SIM slot for optional 4G/5G module (not included)
GNSS (optional) Dual-band L1/L2/L5, RTK-capable
Interfaces
USB 4 × USB 3.2 Type-A (2 × 5 Gbps, 2 × 10 Gbps), USB 3.2 Type-C
I/O 4 × PWM
Display 2 × HDMI 2.0 (3840 × 2160 @ 60 Hz)
Audio 2 × 3.5 mm jack (mic in, line out)
Mechanical and Environmental
Power supply 9–36 V DC, max. 250 W; transient, reverse polarity and ESD protection
Cooling Active
Enclosure Industrial aluminum enclosure, black
Dimensions (L × W × H) 261.5 × 206.5 × 84.8 mm
Operating temperature -25 °C to +50 °C (storage -40 °C to +85 °C)
Software
Operating system Ubuntu 24.04 (L4T)
Preinstalled Stereolabs ZED SDK
Supported ROS 2, NVIDIA Isaac ROS
Scope of Delivery
  • 1× Stereolabs ZED Box 2 Max – T4000 (with selected options)
  • 1× power supply
  • 2× GMSL2 cable 1-to-4
  • 1× USB-C to USB cable
  • 2× Wi-Fi antenna (2.4/5 GHz)
  • 2× GNSS antenna L1/L2/L5 (GNSS variant only)
Cameras and 4G/5G module are not included.
Internal SSD storage
POE+
GNSS
Price on request
  • Available immediately
