Stereolabs ZED Box NVIDIA® Jetson Orin™ NX 8GB
- SKU: MBS-ENTB-84
- Category: Development Boards
Manufacturers:
- Scalable AI performance: NVIDIA Jetson Orin from Nano 4 GB to NX 16 GB, up to 157 TOPS
- Native GMSL2 connectivity: up to four GMSL2 cameras or two ZED X – synchronised and low-latency
- Ready to run: ZED SDK and drivers pre-installed, ROS 2 integration documented
Stereolabs ZED Box Orin – Embedded AI Computer for 3D Perception
The ZED Box Orin from Stereolabs is a compact embedded PC based on the NVIDIA® Jetson Orin™ platform. It processes the data from ZED stereo and mono cameras directly on the machine – without the detour via an external industrial PC. Camera, computer and ZED SDK thus form a ready-to-run unit for spatial perception in robotics, automation and video analytics.
The rugged aluminium housing is designed for continuous operation in industrial environments and works without moving parts. Mounting requires no drilling – fit the bracket, connect the plugs, power up.
Your advantages at a glance
- Scalable computing power: Jetson Orin Nano 4 GB to Orin NX 16 GB – up to 157 TOPS of AI performance depending on the module
- Native GMSL2 connectivity: optional quad GMSL2 interface for up to four GMSL2 cameras or two ZED X / ZED X Mini – synchronised and low-latency
- USB cameras still supported: 3× USB 3.2 Gen 2 for ZED 2i, ZED Mini and ZED 2
- Flexible power supply: PoE+ (up to 15 W) or external 12 V/5 A power supply – a single Ethernet cable carries both data and power
- Optional modules: WiFi/Bluetooth and RTK GNSS for precise outdoor localisation
- Ready to run: pre-installed drivers, ZED SDK and verified compatibility with all current ZED cameras
Software and integration
The ZED Box Orin runs NVIDIA JetPack on Ubuntu 22.04 and ships with the ZED SDK. Development is done in C++, Python or C# – integration with ROS 2, OpenCV, YOLO, GStreamer and Unreal Engine is documented and proven. Depth imaging, object detection, skeleton tracking and spatial mapping all run fully GPU-accelerated on the device.
Typical applications
- Mobile robots and AMRs with all-round perception
- Autonomous commercial and agricultural machinery
- Drones and inspection systems
- Intelligent video analytics in logistics, production and infrastructure
- Research and prototyping with ROS 2
- 1× ZED Box in the selected configuration
- 1× Power supply
- 2× Mounting brackets
- 1× 1-to-4 GMSL2 cable
- 1× Mini-USB to USB cable
- 2× WiFi antennas (2.4/5 GHz)
| Item information | Value |
| Shipping weight: | 1,30 kg |
| Item weight: | 0,70 kg |
