UFactory 850 DC Control Box
- SKU: MBS-Z1-112
- Category: Accessories
Manufacturers:
- 1/3 smaller and lighter than AC Control Box
- Dimensions: 262x160x76 mm
- Weight: 2.8 kg
- Ethernet/RS-485
- 48V Li-Po Battery
The DC Control Box is a fully functional and space-saving control box. It is designed for mobile platform applications.
Like the AC Control Box, this box features the same mainboard and I/O extension. It can execute the same code as the AC Control Box but is 1/3 lighter and smaller due to the removal of the power supply. It operates solely on 48V DC.
This box is compatible with a 48V Li-Po battery, which also powers the UFactory 850 Robotic Arm.
Technical Specifications
- Dimensions: 262 x 160 x 76 mm
- Weight: 2.8 kg
- Ethernet/RS-485 Master*1, RS-485 Slave*1
- Input: 48-72VDC
- Output: 48VDC 960W max
- Control Box I/O: 8*CI+8*DI (digital in) - 8*CO+8*DO (digital out) | 2*AI (analog in) - 2*AO (analog out)
Package Includes
- 1 x UFactory 850 DC Control Box
| Item information | Value |
| Item weight: | 2,80 kg |
