Unitree G1 PLUS
  • SKU: 1445
  • HAN: G1+
  • Category: Hexapod
Unitree G1 PLUS
  • Sold by QUADRUPED
  • Available in different versions: Base, EDU Professional, EDU Ultimate
  • Tactile sensing in the head
  • Continuous mains operation
  • Articulated neck
  • Dual camera system
Unitree G1+ – the humanoid, upgraded all round
The G1+ is the revised version of the Unitree G1. Mechanical platform, dimensions, battery and basic architecture remain the same – what Unitree has changed is everything that used to hit its limits in research and demonstration use: motion performance, perception and interaction. Six upgrades arrive at once.
The most noticeable change is the new neck with two degrees of freedom. The head now turns and tilts on its own, which allows more natural interaction and points the cameras where they are needed without turning the whole upper body. Added to this are stronger shoulder, hip and arm motors that generate considerably less heat at the same torque, a new camera system consisting of a binocular and a wide-angle camera, and continuous mains operation – for trade-show stands and lab experiments where two hours of battery life used to be too short.
The six upgrades at a glance
  • Articulated neck: +2 degrees of freedom, tilt −25° to 36°, rotation ±110°
  • Stronger motors: shoulder and hip +110 % peak torque with 72 % less heat; arms +43 % with 30 % less heat; thighs 28 % less heat at the same torque
  • Dual camera system: binocular camera for depth perception plus wide-angle camera in the chest
  • Tactile sensing in the head: a tap starts a dialogue or triggers a movement
  • Continuous mains operation: external power supply for long operating times
  • Better sound: 6-microphone array with direction finding, two 10 W speakers in the hip
What changes compared to the G1
Feature G1 G1+ Change
Head / neck fixed, no degrees of freedom 2 degrees of freedom, tilt −25° to 36°, rotation ±110° new
Total degrees of freedom 23 · EDU 23–43 25 · EDU 25–71 +2
Standing height 1,320 mm 1,340 mm +20 mm
Shoulder and hip motors baseline +110 % peak torque, −72 % heat at the same torque improved
Arm motors baseline +43 % peak torque, −30 % heat at the same torque improved
Thigh motors baseline −28 % heat at the same torque improved
Arm payload approx. 2 kg · EDU approx. 3 kg approx. 3 kg · EDU approx. 4 kg +1 kg
Cameras depth camera binocular camera in the head plus wide-angle camera in the chest new
Tactile sensing – in the head, a tap starts a dialogue or movement new
Microphones 4-mic array 6-mic array (4 front, 2 rear), direction finding, external wireless microphones possible improved
Speakers 1× 5 W 2× 10 W in the hip improved
External power supply – continuous operation and charging while running new
Legs, footprint, weight 6 DOF per leg, approx. 35 kg, folded 690 × 450 × 300 mm 6 DOF per leg, approx. 35 kg, folded 690 × 450 × 300 mm unchanged
Arms 5 DOF per arm, span approx. 0.45 m 5 DOF per arm, span approx. 0.45 m unchanged
Compute, LiDAR, wireless 8-core CPU, 3D LiDAR, WiFi 6, Bluetooth 5.2 8-core CPU, 3D LiDAR, WiFi 6, Bluetooth 5.2 unchanged
Battery and runtime 9,000 mAh quick-swap battery, approx. 2 h 9,000 mAh quick-swap battery, approx. 2 h unchanged
Warranty 8 months · EDU 18 months 8 months · EDU 18 months unchanged
Technical data G1+ and G1+ EDU
Feature G1+ G1+ EDU
Dimensions standing 1,340 × 450 × 200 mm 1,340 × 450 × 200 mm
Dimensions folded 690 × 450 × 300 mm 690 × 450 × 300 mm
Weight with battery approx. 35 kg approx. 35 kg and more, depending on configuration
Total degrees of freedom 25 25 to 71
Head 2 2
Per leg 6 6
Waist 1 1, optionally 3
Per arm 5 5
Per hand – 1 to 20 depending on gripper or hand, Plus base adds +2 in the wrist
Joint ranges Waist Z ±155° · Knee 0–165°
Hip joint P ±154°, R −30–+170°, Y ±158°
as G1+, plus wrist P ±92.5°, Y ±92.5°
Arm payload approx. 3 kg approx. 4 kg
Lower leg and thigh 0.6 m 0.6 m
Joint mechanics industrial crossed roller bearings, low-inertia inner-rotor PMSM, dual encoders, fully internal cable routing, local air cooling
Binocular camera 60 mm baseline, 2 MP, FOV H 110° / V 80° / D 125°
Wide-angle camera 1920 × 1080 at 30 fps, FOV H 117° / V 67°
Further sensors 3D LiDAR, tactile sensors in the head
Audio 6-microphone array with direction finding, 2× 10 W speakers
Compute 8-core CPU 8-core CPU, optional high-performance module, e.g. NVIDIA Jetson Orin
Wireless WiFi 6, Bluetooth 5.2
Power 13S lithium quick-swap battery 9,000 mAh, runtime approx. 2 h; external power supply for continuous operation; charger 54 V / 5 A
Software OTA updates OTA updates, secondary development supported
Warranty 8 months 18 months
G1+ EDU configurations
The G1+ EDU is available in several configuration levels. Compared with the G1+, the EDU Standard version adds a 100 TOPS compute module, release for secondary development, 4 kg arm payload, the protective bracket and an 18-month warranty. The Plus version extends waist and arms to 31 degrees of freedom. The Professional versions combine the Standard base, the Ultimate versions the Plus base, each with a pair of hands or grippers.
Version Base Equipment Total DOF Tactile
EDU Standard G1+ 100 TOPS compute module, secondary development enabled, arm payload 4 kg, protective bracket, 18-month warranty 25 –
EDU Plus EDU Standard Waist 3 DOF (Z ±155°, X ±30°, Y ±30°), arms 7 DOF per arm (wrist P ±92.5°, Y ±92.5°) 31 –
EDU Ultimate A EDU Plus Dex3-1 three-finger hand with wrist camera 45 –
EDU Ultimate B EDU Plus Dex3-1 three-finger hand with wrist camera, 33 tactile sensors per hand 45 yes
EDU Ultimate C EDU Plus Inspire DFQ five-finger hand with wrist camera 43 –
EDU Ultimate D EDU Plus Inspire E2 five-finger hand with wrist camera, 17 tactile sensors per hand 43 yes
EDU Ultimate E EDU Plus BrainCo Revo 2 Basic bionic hand with wrist camera 43 –
EDU Ultimate F EDU Plus BrainCo Revo 2 Touch bionic hand with wrist camera, pressure, friction, direction and proximity sensing 43 yes
EDU Ultimate G EDU Plus DEX 2/5 tendon-driven hand, no external wiring 35 –
EDU Ultimate H EDU Plus Dex1-1 Plus parallel gripper with wrist camera, gripping force 5–120 N 33 –
EDU Ultimate I EDU Plus WuJi Hand 2 five-finger hand with 20 active DOF and wrist camera 71 –
EDU Professional A EDU Standard Dex3-1 three-finger hand with wrist camera 39 –
EDU Professional B EDU Standard Dex3-1 three-finger hand with wrist camera, 33 tactile sensors per hand 39 yes
EDU Professional E EDU Standard BrainCo Revo 2 Basic bionic hand with wrist camera 37 –
EDU Professional F EDU Standard BrainCo Revo 2 Touch bionic hand with wrist camera, pressure, friction, direction and proximity sensing 37 yes
EDU Professional G EDU Standard DEX 2/5 tendon-driven hand, no external wiring 29 –
EDU Professional H EDU Standard Dex1-1 Plus parallel gripper with wrist camera, gripping force 5–120 N 27 –
EDU Professional I EDU Standard WuJi Hand 2 five-finger hand with 20 active DOF and wrist camera 65 –
G1+ or G1+ EDU?
The G1+ is intended for demonstration, interaction and teaching, where the robot works with its factory functions. Anyone who wants to develop their own software, use dexterous hands or add extra computing power needs the G1+ EDU – it is the only version released for secondary development. We will be happy to advise you on the right configuration and on integration into ROS 2.
  • 1× Unitree G1+ or G1+ EDU in the selected configuration
  • 1× smart battery 9,000 mAh with quick swap
  • 1× charger 54 V / 5 A
  • 1× handheld remote controller
  • 1× protective bracket (not included with G1 PLUS Base)
Contact data
Price on request
  • Currently out of stock
