Voltera V-One PCB Printer
  • SKU: MBS-VOLT-01
  • GTIN: 0096718606610
  • HAN: 1000330
  • Category: Voltera
Voltera V-One
  • Create your own printed circuit boards
  • All-in-one solution thanks to solder paste dispensing and reflow
  • Create your prototypes directly on your desk
Create your hardware
Thanks to Voltera V-One you create your prototype on your desk
The Voltera V-One brings quick-to-create PCBs to your desktop. Simply import your Gerber file into the Voltera software, press "Print" and watch your PCB get created. Thanks to the solder paste dispensing and reflow features, easily mount components on your PCB, or mount components on a pre-made PCB with ease!
All-in-one solution: solder paste dispensing and reflow
The Voltera V-One creates two-layer prototype PCBs, simply loading the Gerber file and printed circuit boards come out. The dispenser applies a silver-based conductive ink and prints your circuit right before your eyes. With V-One's solder paste dispensing and reflow capabilities, mounting conventional and additive circuit boards is easy. Simply install the board on the print bed, then import the Gerber file into Voltera software.
No more need for stencils
Voltera's software is designed to be easy to understand. From importing a Gerber file to pressing a button, the software guides you safely through each step. Compatible with EAGLE, Altium, KiCad, Mentor Graphics, Cadence, DipTrace, Upverter. The V-One Desktop PCB Printer includes all the accessories and consumables you need to get started:
Consumables
  • V-One
  • V-One Dispenser
  • V-One Probe
  • Nozzle Set
  • Nozzle Tip Caps
  • 3" x 4" FR1 Substrate Pack
  • 2" x 3" FR1 Substrate Pack
  • Substrate Clamps
  • Thumbscrew Set
  • Hello World Kit
  • Solder Wire
  • Tweezers
Plus the required power supply, power adapter, cables, and user guides
Accessories
  • 2 substrate clamps and thumbscrews
  • 2 dispensers with caps
  • 1 probe - 1 drill
  • 1 set of safety glasses
  • 1 Voltera anti-static tweezers
  • Print specifications Minimum trace width 0.2 mm
  • Minimum passive size 1005
  • Minimum pin-to-pin distance (conductive ink) 0.8 mml
  • Minimum pin-to-pin distance (solder paste) 0.5 mml
  • Resistivity 12 mΩ/sq @ 70 um
  • height Substrate FR4
  • Maximum board thickness 3 mm
  • Soldering specifications
  • Solder paste alloy Sn42/Bi57.6/Ag0.4
  • Solder wire alloy SnBiAg1
  • Temperature of soldering iron 180-210°C
Print bed
  • Print area 135 x 113.5 mm
  • Max. Heating bed temperature 240°C
  • Heating bed rising speed ~2°C/s
Dimensions/Weight
  • Dimensions (L x W x H) 390 x 257 x 207 mm
  • Weight 7 kg
System requirements
  • Compatible operating systems Windows 7 or higher, MacOS 10.11 or higher
  • Compatible file format Gerber
  • Connection type Wired USB
Certification
  • EN 61326-1:2013 EMC requirements
  • IEC 61010-1 Safety requirements
  • CE marking on Voltera V-One printers supplied to European customers
Shipping weight: 12,00 kg
Item weight: 7,00 kg
Others (2)
Technical data sheet V-One
Safety data sheet conductive ink and solder paste
€ 5.400,00
Manufacturers recommended retail price: € 5.599,00
(Save 3.55%, i.e. € 199,00)
Docs MYBOTSHOP documentation
