ARK RTK GPS
DIU Blue UAS Framework listed, open source, Dronecan L1/L2 RTK GPS, F9P, magnetometer, barometer, IMU, buzzer, and safety switch module
  • DIU Blue UAS Framework Listed
  • Runs PX4 Open Source Firmware
  • Supports Dronecan Firmware Updating
  • Open Source Schematic and BOM
General
The Dronecan RTK GPS, Magnetometer, Barometer, IMU, Buzzer, and Safety Switch Module is DIU Blue UAS Framework Listed and runs PX4 Open Source Firmware. It supports Dronecan Firmware Updating and features an open source schematic and BOM.
The module includes a Ublox F9P GPS receiver for L1/L2, offering centimeter-level positioning in seconds with GPS, GLONASS, Galileo, and BeiDou support. Additional sensors include a Bosch BMM150 Magnetometer, Bosch BMP388 Barometer, and Invensense ICM-42688-P 6-Axis IMU. The STM32F412CEU6 MCU controls the module’s functions.
It features LED indicators for Safety, GPS Fix, RTK Status, and RGB System Status, and is built in the USA and FCC compliant. Power requirements are 5V with 170mA average and 180mA maximum. The package includes a 4 Pin Pixhawk Standard CAN Cable and a Dual Band (L1/L2) Helical GPS Antenna. Alternative antenna options are: Tallysman 33-HC882-28, Taoglas AA.175.301111, Taoglas A.80.A.101111, Linx ANT-GNRM-L12A-3, and Ublox ANN-MB-00-00.
Technical Specifications:
  • Dronecan RTK GPS, Magnetometer, Barometer, IMU, Buzzer, and Safety Switch Module
  • Sensors:
    • Ublox F9P GPS: L1/L2, Multi-Band GNSS receiver with centimeter-level accuracy, concurrent reception of GPS, GLONASS, Galileo, and BeiDou, Multi-band RTK with fast convergence times and reliable performance, high update rate for dynamic applications
    • Bosch BMM150 Magnetometer
    • Bosch BMP388 Barometer
    • Invensense ICM-42688-P 6-Axis IMU
  • STM32F412CEU6 MCU
  • Safety Button
  • Buzzer
  • Two Pixhawk Standard CAN Connectors:
    • 4 Pin JST GH
  • F9P “UART 2” Connector:
    • 3 Pin JST GH, TX, RX, GND
  • Pixhawk Standard Debug Connector:
    • 6 Pin JST SH
  • LED Indicators:
    • Safety LED
    • GPS Fix
    • RTK Status
    • RGB System Status
  • USA Built
  • FCC Compliant
  • Power Requirements: 5V, 170mA Average, 180mA Max
  • Dimensions (without Jetson and flight controller module): 116mm x 72mm x 23mm
  • Operating Temperature Range: -20°C to 70°C
Included in the Package:
  • 4 Pin Pixhawk Standard CAN Cable
  • Dual Band (L1/L2) Helical GPS Antenna
  • Documentation
Item weight: 0,02 kg
€ 904,95
Docs MYBOTSHOP documentation
