ARK Flow LR
ARK Flow LR
  • Optical flow, distance sensor and IMU for GPS-denied flight
  • Altitude measurement from 0.6 to 100 m
  • DroneCAN for PX4 and ArduPilot, NDAA compliant
ARK Flow LR – optical flow and long-range distance sensor with DroneCAN
The ARK Flow LR enables drones and unmanned aerial vehicles to fly in GPS-denied environments – such as inside buildings, halls or tunnels. The module combines an optical flow sensor, a long-range time-of-flight distance sensor and a 6-axis IMU on a compact board.
The PixArt PAA3905 flow sensor works from a distance of 80 mm and automatically detects challenging surfaces such as checkerboard and stripe patterns or glossy surfaces. An integrated IR LED supports operation in low light. The Broadcom AFBR-S50EX85D distance sensor provides altitude readings from 0.6 to 100 m – significantly more than previous flow modules.
The ARK Flow LR is a direct drop-in replacement for the ARK Flow, connects to PX4 or ArduPilot flight controllers via DroneCAN, supports ROS 2 and is manufactured in the USA and NDAA compliant.
  • Optical flow, distance sensor and IMU in one module
  • For GPS-denied flight, e.g. inside buildings and tunnels
  • Distance measurement from 0.6 to 100 m at 10 Hz
  • Automatic detection of challenging surfaces and integrated IR LED for low light
  • Drop-in upgrade for the ARK Flow
  • Compatible with PX4 and ArduPilot, ROS 2 support via ros2_dronecan
  • Firmware updates via DroneCAN/UAVCAN
  • Made in USA, NDAA compliant
Optical flow sensor PixArt PAA3905 (PAA3905E1-Q)
Flow sensor working distance 80 mm to infinity
Flow sensor field of view 42°
IR LED 40 mW, for low-light operation
Distance sensor Broadcom AFBR-S50EX85D (time-of-flight)
Distance range 0.6 to 100 m (typically up to 80 m), 10 Hz
Laser 850 nm, laser class 1 (eye-safe), beam 2° × 2°
IMU InvenSense IIM-42653, 6-axis
CAN 2× Pixhawk standard CAN connector, 4-pin JST GH
Debug 1× Pixhawk standard debug connector, 6-pin JST SH
Protocol DroneCAN
Firmware compatibility PX4, ArduPilot, ROS 2
Power supply 5 V, 86 mA average, max. 90 mA
Status indication LED indicators
Dimensions 3.0 × 3.0 × 1.4 cm
Weight 5 g
Origin Made in USA, NDAA compliant
Notes
  • The achievable range of the distance sensor depends on lighting and the ground surface.
  • The ARK Flow LR uses its own firmware and replaces the ARK Flow without mechanical changes.
  • 1× ARK Flow LR
  • 1× Pixhawk standard CAN cable, 4-pin
Shipping weight: 0,20 kg
Item weight: 0,01 kg
€ 690,95
