Clearpath Warthog
  • SKU: MBS-CP-04
  • HAN: 013242
  • Category: Robots
Clearpath Robotics Warthog
  • Off-Road capable UGV (IP65 protected)
  • Integrated Encoder, IMU & PC
  • Modular expandable
  • Optimized for teaching & research
The platform can be customized for different fields of applications. For more extensive consulting feel free to contact us at any given time.
Please contact us before placing your order to discuss possible upgrades, customizations or special configurations.
Additional costs may be incurred depending on the scope of modifications.
The Warthog is one of the biggest UGV's (Unmanned Ground Vehicle) produced by the canadian company Clearpath Robotics. The robot has a length of 1,5m and is IP65 protected resulting in the robot resisting almost every weather conditions. The robot also comes with an 105Ah battery making it the optimal choice for the off-road usage.
To expand the possible fields of applications there can be used additional modules such as the following ones:
For a more detailed list of the possible expansions feel free to contact us.
Dimensions
Technichal data
  • Dimensions: 1520 x 1380 x 830mm
  • Weight: 280Kg
  • Payload: Max. 272kg
  • Indoor / Outdoor
  • to be stored at -40°C to 50°C
  • Speed: 5m/s
  • Operating time: 2,5h
ROBOTIQ 3-Finger Gripper
Robotiq 3-Finger Gripper Universal Robot Kit
  • 15-60N per Finger
  • Repeatability up to 0,05mm
  • Gripping speed up to 110mm/sec
  • Maximum payload : 10kg
Special prices for Universities & Research institutes! All prices have VAT included.
€ 23.752,40 *
Universal Robots UR5/UR5e
Universal Robots UR-5 Series
  • 850mm working radius
  • 5kg payload
  • Controller: CB3/CB5 & 12" Polyscope control panel
  • Voltage: DC or AC
  • Versions: CB3 (AC only), CB5
  • selectable: with or without teach pendant
  • Each UR is delivered incl. control cabinet & robot arm
Exclusive education discount available!
€ 29.155,00 - € 36.890,00 *
UFactory xArm
UFactory xArm
UFactory xArm
  • Payload: 3 / 5 / 3,5Kg
  • Repeatability: +/- 0,1mm
  • Range: 700mm
  • DOF: 5 / 6 / 7
  • Weight: 11,2 / 12,2 / 13,7Kg
  • Intelligent power management: AC & DC control box available for order
from
€ 4.049,95 *
ROBOTIQ 2-Finger Gripper 85 & 140mm
Robotiq 2-Finger Gripper Universal Robot Kit
  • Gripper range depends on the version: 0-85mm / 0-140mm
  • Gripping Force: 2F85 20-235N / 2F140 10-125N
  • Closing Speed: 2F85 20-150mm/s / 2F140 30-250mm/s
  • Weight: 2F85 900g. / 2F140 1000g
Special prices for Universities & Research Institutes! Prices have VAT included.
€ 4.566,95 - € 5.803,95 *
Stereolabs ZED 2i Stereo Kamera (IP66 & Polarizing...
Stereolabs ZED 2i Stereo Kamera (IP66 & Polarizing Filter) 2,1 mm
Stereolabs ZED 2i 3D-Camera
  • 2K Video Stream
  • IP66 geschützt
  • Integrated IMU, Barometer & Magnetometer
  • Compact & resilient aluminium case
  • Lens Focal Length: 2,1 mm
€ 659,95 *
HOKUYO UTM/UXM-Series LiDAR
Hokuyo UTM/UXM LiDAR
  • Up to 80m Range
  • 270° View
  • USB / 100BASE-TX Interface (depends on the version)
  • IP64 / IP67 Protection (depends on the version)
€ 2.399,00 - € 5.354,95 *
Universal Robots UR3/UR3e
Universal Robots UR-3 Series
  • 500mm Working Range
  • 3kg Payload
  • Controller: CB3/CB5 & 12" Polyscope Control Panel
  • Repeatability: 0,1mm (UR3) | 0,03mm(UR3e)
  • Force Momentum Sensor (UR3e)
  • Every UR will be delivered incl. Control Box, Teach Pendant and Robot arm
€ 23.681,00 - € 30.938,81 *
Universal Robots UR10/UR10e
Universal Robots UR-10 Series
  • 1300mm Working Range
  • 10kg Payload
  • Repeatability: 0,1mm (UR10) | 0,03mm(UR10e)
  • Force Momentum Sensor (UR10e)
  • Every UR will be delivered incl. Control Box, Teach Pendant & Robot arm
€ 36.473,50 - € 47.975,00 *
Shipping weight: 700,00 kg
Item weight: 280,00 kg
Clearpath Warthog Datasheet
€ 92.901,00
