DYNAMIXEL Pro+ H54P-200-S500-R
- SKU: MBS-ANT-34
- GTIN: 0096718607013
- HAN: 902-0079-001
- Category: Electronics
Manufacturers:
ROBOTIS Dynamixel Pro H54P-200-S500-R Servomotor
- Resolution up to 1 003 846 Steps/Pulse
- Position, Speed and Power sensor
- RS485 Interface/Communication
- Up to 29 RPM
General
The ROBOTIS Dynamixel Pro+ servos have different power values, dimensions and interfaces and therefore cover a wide field of possible applications. The Dynamixel Pro+ H54P-200-S500-R has an epicyclic gearing aswell as an integrated encoder that enables up to 1 003 846 steps/pulse. Furthermore the Dynamixel Pro servos have following special functions:
- current sensor for force control
- control algorithm for speed, position and voltage regulation
- PID-Controller for intern position control
The communication betwwen the servomotor and the controling unit can be realised via the ROBOTIS Dynamixel U2D2, the ROBOTIS OpenCR1.0 or a variety of other Dynamixel Pro RS485 compatible units. One thing that should be kept in mind is, that the working voltage is 24 Volt.
Technical Data
- Model Name: H54P-200-S500-R
- ROBOTIS item number: 902-0079-001
- Resolution: 1 003 846 Steps/Pulse (0.0004°)
- Weight: 0,855Kg
- Dimensions: 54 x 54 x 126mm
- Working voltage: 24V
- Maximum torque: 29 RPM
- Engine type: BLDC (Maxon)
- Current: up to 9,3A
- Toruqe: 44,7Nm
- Gear ratio: 501,9:1
- Interface: RS485 (Half Duplex, 8bit, 1 Stop Bit, No Parity)
- Working temperature: -5° - 55°C
- Mode: Torque, Velocity, Position, Extended Position & PWM Control
- ID: 0 - 252
The full manual of the Dynamixel Pro servos can be HERE.
Default settings
When delivered everey DYNAMIXEL Pro servo has the ID:1 and an baudrate of 57 600bps
- DYNAMIXEL H54P-200-S500-R
- 2x X4P 600mm Data & Power cable
- 20x WB M3x8mm
| Item information | Value |
| Shipping weight: | 1,50 kg |
| Item weight: | 0,86 kg |
