Holybro ELRS Nano Receiver
  • RP1, RP2, RP3
  • The RP1 and RP2 receivers in the 2.4 GHz ELRS Nano series are open source receivers (ExpressLRS)
  • Type: ISM
  • Bus interface: CRSF
The RP1 and RP2 2.4GHz ELRS Nano receivers are open-source modules based on ExpressLRS.
These compact Nano receivers were originally developed by Jye Smith from the ExpressLRS development team and are equipped with an ESP8285 MCU and an SX1280 RF chip. While the RP1 features a UFL antenna socket for full-range antenna use, the RP2 has a built-in ceramic antenna that is particularly lightweight and space-saving—ideal for racing applications.
Both models come with built-in WiFi, allowing for wireless firmware updates and easy configuration via the integrated WebUI using a PC or mobile device.
With their low-latency, high-refresh-rate RF module, the RP1 and RP2 are perfect for FPV racing and long-range flights. Thanks to their ultra-lightweight and compact design, they are highly versatile—whether for Whoops, drones, or fixed-wing models, these receivers fit just about anywhere!
Shipping weight: 0,20 kg
Item weight: 0,00 kg
from
€ 25,95
  • Available immediately
