Holybro S500 V2 Kit ARF
  • SKU: MBS-HOLY-12
  • GTIN: 0658917512576
  • HAN: 30062
  • Category: Accessories
Holybro S500 V2 Kit
  • Lightweight, easy to assemble, no soldering required
  • Compatible with various Holybro Flight Controllers like Pixhawk6C, Pix32 v6
  • Strong and lightweight quadcopter frame with built-in power distribution
  • Dimensions: 383 mm x 385 mm x 240 mm
  • Weight: 782 g
The Holybro S500 V2 Kit is an affordable, lightweight, and easy-to-assemble solution that requires no soldering. This complete kit includes almost everything you need to fly. All you will need in addition is a battery and an optional RC system. It is perfectly compatible with various Holybro Flight Controllers like the Pixhawk6C, Pix32 v6, etc.
The S500 frame is made from a mixture of materials. The arms are constructed from high-strength, ultra-durable Polyamide-Nylon composite material reinforced with a carbon fiber rod through the center. The landing gear consists of 16 mm and 10 mm diameter carbon fiber tubes connected via plastic tee connectors that have been thickened and strengthened compared to the previous version.
This is an excellent strong and lightweight quadcopter frame with landing gear and a 1.5 mm top and bottom plate. The bottom plate also has a built-in power distribution board (PDB) for neat and easy wiring. It also features an adjustable battery mount to achieve the perfect weight distribution. The bottom frame is ready to take a whole host of camera mounts and gimbals, making it perfect for various applications.
Assembly of this frame is super simple due to the pre-threaded sleeves for all the frame bolts, so lock nuts are not required. It utilizes one size bolts for the entire build, meaning you only need one size hex for the assembly.
Technical Specs
  • Wheelbase: 480 mm
  • Weight: 782 g
  • Motors: 2216 KV920 (V2 Update)
  • BLHeli S ESC 20A, built-in PDB (Continuous: 60A, Burst: 100A)
Contents
  • 1x Holybro S500 V2 Kit
  • Motors, propellers (1045, V2 Update), battery straps
Contact data
€ 349,99
  • Goods ordered. 13 expected on 11.12.2026.
