Intel® RealSense Depth Camera D435if incl. accsessories
  • SKU: MBS-SES-298-02
  • GTIN: 0658917502447
  • HAN: 82635D435IF 99C9LT
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Camera D435if
  • Intel® RealSense™ Depth module D430
  • IR pass filter
  • up to 1920 x 1080 RGB resolution
  • range 0.2 m to over 10 m (varies depending on lighting conditions)
D435if = Intel RealSense D435 Camera + IMU (i) + Polarizing (iR) filter (f)
The Intel RealSense D435if combines a powerful depth camera (D435) with an Inertial Measurement Unit (IMU) and a Polarization Filter (iR). This innovative trio enables precise depth perception, motion detection, and reduces distracting light reflections. The D435if is the ideal solution for outdoor applications that require high-quality 3D data under a wide range of conditions, whether in robotics, augmented reality, or other fields where accuracy and reliability are critical.
Software
Thanks to IR now with improved depth quality
The Intel® RealSense™ D435f depth camera expands the RealSense portfolio for the growing autonomous mobile robot market. The IR pass filter significantly improves the quality of depth noise, as well as the performance range for many robotic environments.
  • IR pass filter
  • up to 1920 x 1080 RGB-Resolution
  • FOV: 90°
  • Range: 0,2 - 10m (Depending on lightning conditions)
  • USB-C* 3.1 Gen 1 connector
  • Dimensions 90 * 25.8 * 25 mm
  • Intel RealSense D435if Depth Camera
  • USB cable
  • Tripod
Shipping weight: 0,31 kg
Datasheet D400 Series
Accessories
€ 456,32
Others also bought:
