LIPSedge L210u Structure Light module
- SKU: MBS-SES-329
- GTIN: 0658917512873
- Category: 3D Machine Vision
Manufacturers:
LIPSedge L210u Structured Light Module
- Compact RGB-D structured-light sensor
- Optimized for short-range applications (0.3m to 1m)
- Accuracy: Up to 0.3% @ 100 cm
- Small form factor: 54 x 25 x 11.3 mm
- VCSEL @ 940nm, suitable for both indoor & outdoor use
The LIPSedge L210u Structured Light camera provides a powerful solution for short-range 3D sensor applications. With high accuracy of up to 0.3% at 100 cm and a maximum range of 1.2 meters, this camera is ideal for applications such as 3D scanning, 3D facial recognition, and 3D measurement. Equipped with a compact design and a 940 nm VCSEL infrared light source, it is suitable for both indoor and outdoor use. The small form factor and high cost-effectiveness make the L210u an ideal alternative for customers transitioning from RealSense systems.
The camera features a depth frame rate of 1280x800 at 6 fps and 640x480 at 25 fps, making it capable of delivering precise results even in dynamic scenes. 3D data is generated using a global shutter and vertical-cavity surface-emitting laser (VCSEL), which enhances measurement accuracy and robustness. The LIPSedge L210u module is the perfect choice for industrial applications requiring fast and precise 3D measurements.
LIPSedge L210u/L215u Point Cloud
LIPSMetric Handheld Dimensioner Solution
Technical Specifications
- Depth Technology: Structured Light
- Depth Accuracy: 0.3% @ 100 cm
- Maximum Working Distance: 1.2 m
- Minimum Working Distance: 0.4 m
- Depth Frame Rate (USB Output): 1280x800 @ 6 fps, 640x480 @ 25 fps
- Shutter Type: Global Shutter
- Field of View (H x V): 50.7° x 74.2° (+/-2°)
- RGB Resolution: 1280x800 / 6 fps (YUV), 640x480 / 25 fps (YUV)
- RGB Field of View (H x V): H: 45.89°@UXGA, 38.86°@720p, 45.89°@VGA, V: 58.89°
- RGB Shutter Type: Rolling Shutter
- Illumination Type: Infrared
- Illumination Wavelength: 940 nm
- Illuminating Component: Vertical-cavity surface-emitting laser (VCSEL)
- Dimensions (mm): 54.0 x 25.0 x 11.3 mm
- Weight: 16.4 g
- Ambient Temperature: 0 ~ 40°C
- Storage Temperature: -20 ~ 60°C
- Power: USB Power-in, DC 5V/1A
- Output Interface: Micro USB (USB 2.0)
- SDK: Supported Frameworks: OpenNI, NVIDIA Isaac, ROS
- Operating System: Windows 10, Ubuntu 16.04 / 18.04 LTS / 20.04 / 22.04 LTS
- Environment: Indoor
Included Items
- LIPSedge L210u Structured Light Camera
| Item information | Value |
| Item weight: | 0,00 kg |
