Luxonis DepthAI OAK-D-Pro IMX378 W POE (IP65) Wide Angle
  • 120° DFOV stereo pair for wide depth perception
  • Active stereo: Built-in IR dot projector enhances depth sensing, especially on low-texture surfaces
  • Night vision: Integrated IR LED allows operation in low- or no-light conditions
  • Durable IP65-rated housing – ideal for industrial and outdoor use
  • M12 PoE connector, plus additional M8 connector for I/O integration
The Luxonis DepthAI boards combine stereo or RGB cameras with the Intel® Movidius™ Myriad™ X platform. The result is a small board that can be used either stand-alone or with an additional device such as an NVIDIA Xavier Jetson, Raspberry Pi or many more. Due to the high performance Intel uC with a base clock of 700MHz this small & compact development board can calculate about 4.5 million possibilities in less than a second.
Differences between OAK-D & OAK-D-Pro?
The differences between both models are just the IR lED & Projector which is integrated in the OAK-D-Pro. With this small module ýou will be able to create high quality point clouds with low or no light conditions.
What's the concept behind Luxonis?
The manufacturer wants to create a versatile platform with an extremely small form factor, on the basis of which anyone can execute a first basic script in less than 30 seconds. The development platforms are available in different configurations, such as with WLAN or a Raspberry PI Compute Module. If the first tests are promising, Luxonis also offers only the pure bare PCB's, which can be integrated as an OEM into a third party component.
What is DepthAI?
Every Luxonis development board is based on the DepthAI Firmware which has already the following features implemented:
  • Neural Inference (e.g. object detection, image classification, etc., including two-stage)
  • Stereo Depth (including median filtering)
  • 3D Object Localization (augmenting 2D object detectors with 3D position in meters)
  • Object Tracking (including in 3D space)
  • H.264 and H.265 Encoding (HEVC, 1080p & 4K Video)
  • JPEG Encoding
  • MJPEG Encoding
  • Warp/Dewarp
  • Sensor: IMX378 (PY060)
  • DFOV/HFOV/VFOV: 120°/95°/93°
  • Resolution: 12MP (4056x3040)
  • Focus: FF 60cm - infinity
  • Max framerate: 60FPS
  • Spectral range: visible + 940mm
  • Shutter type: rolling
  • Sensor size: 1/2.3"
  • F-number: 1.8 +/- 5%
  • Effective focal length: 2.75mm
  • Pixel size: 1,55µm
  • 1 x Luxonis DepthAI OAK-D-Pro IMX378 POE
Shipping weight: 0,25 kg
Item weight: 0,18 kg
€ 809,95
