Luxonis OAK 4 D Pro Auto focus
  • SKU: MBS-SES-359-03
  • GTIN: 0658917514440
  • HAN: OAK-4-PRO-AF
  • Category: 3D Machine Vision
OAK 4
  • Version: D Pro
  • 8-core ARM CPU (QC Snapdragon 8 series), 8GB RAM, 128GB storage
  • Powered by Luxonis OS, based on Linux Kernel 5.15
  • Computer Vision: Warp (undistorted), resizing, cropping via ImageManip nodes, edge detection, feature tracking. Also supports custom CV functions
  • AI Performance: 48 TOPs (INT8) and 12 TOPs (FP16) operations
  • Stereo depth perception with filtering, post-processing, RGB-depth alignment, and high configurability
  • Object tracking: 2D and 3D tracking with ObjectTracker node
OAK 4 Features
  • Versions: S, D, D Pro
  Auto Focus Fixed Focus Wide Stereo Pair Stereo Pair - Wide
Sensor IMX586 (PY237) IMX586 (PYXXX) IMX586 (PY262) OV9282 (PY238) OV9282 (PY265)
DFOV 82.4˚ 82.4˚ 120.0˚ 84.5° 149.2°
Resolution 48MP ( 8000x6000) 48MP ( 8000x6000) 48MP ( 8000x6000) 1MP (1280x800) 1MP (1280x800)
Focus AF FF FF FF FF
Max Framerate 30 FPS 30 FPS 30 FPS 60 FPS 120 FPS
Spectral range Visible  Visible Visible  Visible + 940 nm Visible + 940 nm
Shutter Type Rolling Rolling Rolling Global Global
Sensor size 1/2" 1/2" 1/2" 1/4" 1/4"
F-number 1.79 ± 5% 1.79 ± 5% 1.79 ± 5% 2.0 ± 5% 2.0 ± 5%
Effective Focal Length 4.74mm 4.74mm 4.74mm 2.35mm 1.69mm
Pixel size 0.8µm 0.8µm 0.8µm 3.0µm 3.0µm
OAK 4 D Pro – Advanced Edge Computing and Stereo Vision Camera
The OAK 4 D Pro is a state-of-the-art standalone camera unit designed specifically for robotic vision and automated systems. It combines an active stereo depth camera with a high-resolution color camera, offering powerful on-device AI inference and advanced computer vision capabilities.
The Pro version is ideal for applications requiring precise and reliable stereo depth perception, even in challenging environments with low light conditions or textureless surfaces.
Key Features
Integrated RVC4 Technology:
  • 8-core ARM CPU (QC Snapdragon 8 series) with 8 GB RAM and 128 GB storage
  • Operating System: Luxonis OS, based on Linux kernel 5.15
  • Computer Vision: Undistortion, resizing, cropping via ImageManip node, edge detection, feature tracking, and support for custom CV functions
  • AI Performance: 48 TOPs (INT8) and 12 TOPs (FP16) for high-efficiency AI inference
  • Stereo Depth Perception: Filtering, post-processing, RGB-depth alignment, and extensive configuration options
  • Object Tracking: 2D and 3D tracking with the ObjectTracker node
Technical Specifications
  • Baseline Distance: 75 mm
  • Optimal Depth Range: 70 cm – 12 m
  • Power Consumption: Up to 25 W
  • Housing:
    • Rugged aluminum body with Gorilla Glass front cover
    • Water-resistant enclosure with IP67 certification
  • Mounting Options:
    • 1/4" tripod mount
    • 75 mm M4 VESA mount on the back and bottom
  • Dimensions: 143.5 × 42.5 × 67.3 mm
  • Weight: 674 g
This OAK camera features a baseline of 7.5 cm, which is the distance between the left and right stereo cameras. The minimum and maximum depth measurement (MinZ and MaxZ) is influenced by the field of view (FOV), resolution, and baseline of the camera.
  • Recommended depth range: 70 cm – 12 m
  • Minimum depth measurement:
    • ~20 cm (at 400P with extended configuration)
    • ~35 cm (at 400P OR 800P with extended configuration)
    • ~70 cm (at 800P)
  • Depth Measurement Accuracy
    • Up to 4 m: Absolute depth error below 2%
    • 4 m – 7 m: Absolute depth error below 4%
    • 7 m – 10 m: Absolute depth error below 6%
Infrared (IR) Detection
  • This product complies with international safety standards for Class 1 laser products according to EN/IEC 60825-1, Edition 3 (2014).
Active Stereo Technology
  • Uses the Himax Dot-Pattern Infrared Illuminator
  • An IR dot projector enhances depth perception, particularly on surfaces with low optical texture, by projecting thousands of infrared points onto the scene.
Night Vision Mode
  • An IR illumination LED enables AI and computer vision algorithms to function even in low-light or completely dark environments.
Connectivity & Interfaces
  • Power-over-Ethernet (PoE)
  • The camera supports 802.3at PoE (Class 3) and enables 2.5GBASE-T data transfers at speeds of up to 2.5 Gbps (depending on network infrastructure).
  • For optimal PoE functionality, a PoE switch is recommended.
  • M12-PoE connector for power and 2.5 Gbps data transfer
  • M8 connector for I/O connectivity, including:
  • USB2 (D+, D-)
  • Camera I/Os (FSIN, STROBE)
Power supply
  • 2x GPIOs (can also be used for UART)
  • Protective cap for the M8 connector to ensure water resistance when not in use
  • Alternatively, the camera features a USB-C interface (USB 3.2 Gen2, 10 Gbps) as an additional power and data source.
  • Both connection methods can be used simultaneously.
Operational Features & Environmental Resistance
  • Water & Dust Protection
  • IP67-certified housing, protecting the camera from water and dust
Power Consumption
  • 1.5 W – 25 W (depending on usage scenario)
Operating Temperature Range
  • -20 °C to +50 °C
Vibration Resistance
  • Complies with EN 60068-2-6:2008
  • Meets ISO 15998:2008, Section 7.2.3, Table 1
  • 1x OAK 4 D Pro
  • M12 plug to RJ45 cable, 2m
Shipping weight: 0,85 kg
Item weight: 0,67 kg
€ 1.544,95
Docs MYBOTSHOP documentation
