MAUCH 059 Power Cube & PDB Power-Switch
MAUCH 059 Power Cube & PDB Power Switch
  • Works like a manual on/off switch
  • 3D printed bracket
  • Power control mode
The MAUCH 059 Power Cube & PDB Power-Switch functions like a manual on/off switch. The switch connects to any Power Cube "V3" or 030:2x 200A PDB. The item has a small circuit board which is integrated into the main wire. This enables a current control mode. The switch already has a 3D-printed bracket, which can be easily screwed to the main frame. If the bracket is not needed, the Molex 6p housing can be removed and the bracket can be taken off. In the following plug the cables back into the housing.
  • 1x Power-Switch with 200mm connection cable
  • 1x switch holder ABS
  • 2x M3x10 screws, incl. nuts
  • 1x spare Molex 6p housing
Shipping weight: 0,02 kg
Item weight: 0,01 kg
€ 28,95
