Opt Laser XT Serie
Opt Laser XT Serie
  • XT8 and XT-50
  • Plug&Play Laser Kit
  • for All CNC Machines
XT8 45W Plug&Play Laser Kit – Compatible with All CNC Machines
Universal Upgrade Kit: PLH3D-XT8 Laser Module
Key Technical Specifications:
  • Optical Power: 45 W
  • Spot Size: 180 μm at 125 DPI HD resolution
  • Max Cutting Depth (Wood): Up to 20 mm (¾")
Optimized for:
  • High-speed cutting and engraving performance similar to CO₂ lasers – especially effective on thick and durable materials.
Transform Your CNC into a Laser Powerhouse
The XT8 Laser Module delivers a top-tier, industrial-grade upgrade in a Plug&Play format. Developed by leading manufacturer Opt Lasers, it features patented multi-diode technology and exceptional reliability – making it the perfect choice for professionals in manufacturing, prototyping, and advanced CNC applications.
Highlights at a Glance
Extended Focal Depth for Efficient Cutting
  • A wide focal range eliminates the need for constant refocusing, ensuring clean cuts in a single pass – even across uneven surfaces.
Micro-Spot Technology for High Precision
  • Produces a focused laser spot under 200 μm, enabling detailed engravings and clean cuts through wood up to 15 mm thick.
Dual Power Modes for Versatility
  • 50% power for fine grayscale engravings, 100% for fast, high-energy cutting – fully adjustable based on material and use case.
Built-in Air Assist Nozzle
  • Integrated air support increases cutting speeds up to 6× faster while minimizing heat effects and producing cleaner edges.
High-Efficiency Copper Heatpipe Cooling
  • Transfers heat efficiently to external heat sinks, protecting the electronics and ensuring consistent long-term operation.
Safety System with LED Indicators
  • Built-in LEDs display laser readiness, overheating alerts, and status updates – ensuring safe operation at all times.
Ultra-Fast Driver for Precision Modulation
  • The onboard high-frequency driver allows precise laser control, eliminating delays and ensuring razor-sharp engraving performance.
All-Metal Industrial Housing
  • The fully metal casing provides robust protection from environmental and mechanical stress – including a reinforced cable clamp.
  • 1× PLH3D Height Reference Tool (REF: 001955)
  • 1× Laser Safety Glasses (REF: 001138)
  • 1× PLH3D-XT8 45W Cutting and Engraving Laser Head (REF: 004384)
  • 1× PLH3D-CNC Adapter Pro (REF: 004382)
  • 1× 24V 8A Power Supply with US/UK adapters (REF: 004385)
  • 1× Laser Head Cable (7 m / 22 ft) (REF: 004402)
  • 1× OptiShield Beam Cover (REF: 004508)
  • 1× CNC Laser Warning Stickers (REF: 004261)
  • 1× Universal CNC Mount for PLH3D Series Heads (SKU: 004706)
  • 1× Signal Cable for Universal PLH3D-CNC Adapter (SKU: 004821)
XT-50 6W Plug&Play Laser Kit – Universally Compatible with CNC Machines
PLH3D-XT-50 Laser Module: Compact, High-End Precision Upgrade
Core Specs:
  • Optical Power: 6 W
  • Spot Size: 45 μm at Ultra-HD resolution (550 DPI)
  • Max Cutting Depth (Wood): Up to 3 mm (⅛")
Best for:
  • High-precision engraving and cutting of thin materials with ultra-fine detail.
Powerful. Precise. Plug & Play.
The XT-50 stands as one of the most capable single-diode laser heads in its class. Designed for high-resolution engravings and intricate cutting, it integrates seamlessly into nearly any CNC setup thanks to its full Plug&Play accessory set.
Sharp Engraving Even at Full CNC Speeds:
The PLH3D-XT-50 effortlessly engraves wood at maximum feed rates of common CNC machines – delivering ultra-HD detail that rivals finer spot sizes to the naked eye.
Key Features
Precision Square Spot – Adjustable from 25 to 500 DPI
  • Spot size can be focused below 50 μm and widened up to 2 mm using Z-height adjustments – perfect for both tiny details and large-area work.
High Energy Density = Greater Efficiency
  • The focused beam delivers exceptional power density, allowing for faster, cleaner engraving and cutting – even on materials like stainless or tool steel.
Versatile Material Compatibility
  • Cuts and engraves a broad range: wood, cardboard, rubber, paper, textiles, leather, plastic, balsa, plywood – and marks stainless steel, titanium, and heat-sensitive alloys.
Smart LED Safety Indicators
  • Status LEDs indicate when the laser is armed, overheating, or encountering environmental issues – for consistent, safe usage.
Factory-Calibrated Triplet Lens
  • Every laser ships with a precision-aligned high-resolution lens, preset to a 60 mm focus – ready to go right out of the box.
Integrated High-Frequency Driver
  • Direct connection between diode and driver ensures precise current control, shielding from electromagnetic interference during operation.
Passive Cooling, No Extra Fans Needed
  • The aluminum housing doubles as a heat sink – allowing for 24/7 continuous operation with zero external cooling requirements.
Unmatched Optical Accuracy
  • The XT-50's custom-designed optics deliver exceptional engraving clarity, technical precision, and detailed image reproduction.
  • 1× 19V 2.5A Power Supply with global plug adapters (REF: 001952)
  • 1× Laser Head Cable (5.5 m / 18 ft) (REF: 001957)
  • 1× PLH3D-XT-50 Precision Engraving Laser Head (REF: 002425)
  • 1× High-Pressure Air Assist Nozzle Kit for XT-Series (REF: 003806)
  • 1× Set of CNC Laser Stickers (REF: 004261)
  • 1× Universal CNC Mount for PLH3D Laser Heads (SKU: 004706)
  • 1× Signal Cable for PLH3D-CNC Adapter (SKU: 004821)
Contact data
Price on request
  • Currently out of stock
