UFactory uArm Swift Pro
  • SKU: MBS-UA-03
  • GTIN: 0096718605026
  • Category: Robots
The following applications are provided by the different options and you can choose wich apllications you want by selecting the required option.
  • ROS compatible
  • Optimized for educational usage
  • 3D-Printing
  • Machine Vision
General
The uArm Swift Pro is an top-quality robotic arm wich can be used in a wide spectrum applications. The uArm Swift Pro was developed and optimized for educational usage wich results in a lot of packages that are already available for Open Scource platforms such as ROS. The uArm Swift Pro has a position repeatability of 0.2mm and is furthermore equipped with a stepper motor and 12-bits encoder. Those are just some reasons that ends up in the uArm Swift Pro beeing an excellent choice for educational usage. Another great feature is the 3D-Printing Kit wich can be used to convert the uArm Swift Pro into a 3D-Printer in the less then 1 minute.
The uArm support the following development platforms/systems
  • UFACTORY SDK
  • Arduino
  • Python
  • ROS
  • GRABCAD
  • OpenMV
Smartphone APP
You can already get the smartphone app for iOS in the app store wich enables an easy steering and controlling of the robot arm. The app is in development for Andoid and will be available soon.
An example of the Machine Vision
The Following .gif shows the uArm combined with the OpenMV Machine Vision Cam M7 and the face recognition applications that can be implemented in MicroPhyton.
Technical Data
  • Degrees of Freedom: 4
  • Weight: 2,2kg
  • Dimensions: 150 x 140 x 281mm
  • Repeatability: up to 0,2mm
  • Payload: 500g
  • Working Range:50 - 320mm
  • Positioning Speed: 100m/s
  • Position Feedback: 12bit Encoder
The complete datasheet can be looked at HERE if u want to get more information about joint speed & torque, hardware or accessories aswell as the data of the laser. The Laser is not allowed to be selled in germany due to safety-related reasons and is therefore not a part of the package.
Delivery Content
  • UFactory uArm Swift Pro Body
  • Bluetooth & Vacuum Gripper
Shipping weight: 3,95 kg
Item weight: 2,62 kg
Average item rating
Share your experiences with other customers!
All reviews:
How do reviews work?
Total entries: 1
Great product
5 from 5
Great product
Well packed
I highly recommend
Total entries: 1
UFactory uArm Datasheet
€ 941,95
