Pickit 3D Vision Camera
  • three versions
  • L2.0, M-HD, M2.0
  • integrated software
  • image capture time: 200 - 1000 ms
Pickit 3D Vision cameras are supplied with integrated Pickit software.
Three versions are available: Pickit L, Pickit M-HD and Pickit L-HD.
Technical data Pickit L2.0
  • Detects medium sized objects in boxes and on tables and transmits the gripping position to the robot
  • Image processing speed: 30FPS (100ms snapshots)
  • Minimum size: 150x150x50mm
  • Detection range up to Euro pallet size
Technical data Pickit M-HD
  • 3D measurement method: structured light
  • 3D-Bildaufnahmezeit: 200-1000ms
  • resolution: 1920 x 1200 pixels
  • precision*: 0.15-0.8mm
  • accuracy: +/- 0.75%
  • accuracy**: 2-4mm
  • Estimated picking accuracy***: 1.5 x 3D camera accuracy
  • Weight: 2 kg
  • Connection: M12-8 (USB) - USB3
  • PC connection to the robot: TCP/IP via Ethernet
* A larger distance to the camera has a lower 3D camera precision.
** A larger FOV has a lower 3D camera accuracy.
*** Average accuracy from real production environment
Technical data Pickit M2.0
  • Detects small to medium sized objects in boxes and on tables and transmits the gripping position to the robot
  • Camera accuracy: <3mm
  • Camera repeatability: <1mm
  • Minimum object size: 50x50x10mm
  • Pickit 3D Vision Camera
Pickit 3D Kamera Datasheet
Price on request
