ROBOTIS BT-410 USB Dongle
  • SKU: MBS-Z-61
  • GTIN: 8809052930431
  • HAN: 902-0131-000
  • Category: Accesoires
  • BT-410 (Slave) compatible
  • Range up to 10m
  • BT 4.0 Low Energy (25mA)
The ROBOTIS BT-410 USB Dongle enables data trasnmission with a BT-410 Slave wich is connected to a UART port. The guidance including the driver packages can be found HERE allowing for a very easy integration.
Connect Master & Slave
Connecting the BT-410 USB Dongles with a Slave is very intuitive. If the Master is not connected with the Slave it blinks. To connect both devices they need to be ca. 10cm next to each other. When connected the LED stops blinking signalizing a sucessful connection.
  • Dimensions: 50,5 x 20 x 10,5mm
  • Weight: 7,5g
  • BLE: 4.0 Low Energy 2,4GHz
  • Range: 10m
  • Transfer rate: 128kbps
  • USB Interface: 2.0
  • Max. Power consumption: 25mA
  • Operating voltage: 5V
  • ROBOTIS BT-410 USB Dongle
Shipping weight: 0,08 kg
Item weight: 0,01 kg
€ 38,95
