Rotary Encoder - 12mm Hollow Shaft 1000CPR with Index
- SKU: MBS-Z-340
- GTIN: 0658917513757
- HAN: ENC4126_0
- Category: Accessories
Manufacturers:
- 1000 quadrature cycles per revolution
- Rotation speeds of up to 6000 rpm
- Mounting screws included
- Index channel
This optical encoder is able to detect the incremental position of a motor, an axis or a rotating element.
- Generates 1000 quadrature cycles per revolution
- Features an index channel that allows for easy position calibration and zeroing
- Can handle rotational speeds of up to 6000 rpm
- Equipped with a pre-mounted connector for quick and easy connection to Phidgets encoder interfaces
- Mounting screws included for easy installation
Encoder Properties
- Manufacturer Part Number: M38H12-F-(1000)BZ5F2
- Output Circuit Type: Push-Pull
- Controlled By: Encoder Interface
- Encoder Resolution: 1000 CPR
- Encoder Speed Max: 6000 RPM
Electrical Properties
- Supply Voltage Min: 5 V DC
- Supply Voltage Max: 5 V DC
- Current Consumption Max: 60 mA
- Output Frequency Max: 100 kHz
Physical Properties
- Shaft Diameter: (Inner) 12 mm
- Cable Length: 2 m
- Shaft Maximum Axial Load: 15 N
- Shaft Maximum Radial Load: 30 N
- Operating Humidity Max: (Non-condensing) 85 %RH
- Operating Temperature Min: -20 °C
- Operating Temperature Max: 85 °C
- IP Rating: IP55
- Weight: 180 g
Customs Information
- Canadian HS Export Code: 9029.10.00
- American HTS Import Code: 9029.10.80.00
- Country of Origin: CN (China)
- Rotary Encoder - 12mm Hollow Shaft 1000CPR w/ Index
| Item information | Value |
| Shipping weight: | 0,90 kg |
| Item weight: | 0,18 kg |
