SLAMTEC RPLIDAR S1 360° Laser Scanner (40 m)
  • SKU: MBS-SES-99
  • GTIN: 0096718603923
  • Category: Sensors
SLAMTEC RPLiDAR S1
  • Measurement range: 40m
  • Sampling Rate: 9200/sec.
  • Aperture angle: 360°
  • Measurement error: +/- 5cm
Slamtec RPLidar S1 - Powerful and versatile 360° laser scanner RPLidar S1 from Slamtec has a 0.391° angular Resolution.
With its lightweight and compact design, this scanner can be mounted on any indoor or outdoor platform or on mobile robots. The Slamtec RPLidar S1 can perform highly accurate range measurements in virtually any environment, using Time of Flight technology. The S1 offers a maximum range of 40 m for objects with high remission.
Wireless communication and compatibility This 360° LIDAR is 100% compatible with the world of Slamtect and can be used in conjunction with all of the manufacturer's hardware and software interfaces. This supports the development and programming of robotic solutions with laser scanners. To avoid technical failures caused by a multitude of electrical connections, the RPLIDAR S1 laser scanner is equipped with wireless technology for power supply, data transmission and optical communication.
Advantages of the S1:
  • light and compact
  • TOF technology
  • daylight resistant
  • closed cover
  • eye safety standard IEC-60825 class 1
  • compatible with all SLAMTEC hardware/software interfaces
  • Internal wireless technology for power supply, data transmission and optical communication
Technical data:
  • measuring angle: 360°
  • measuring distance: up to 40m
  • TOF technology
  • up to 9200 laser samples per second
  • Sampling frequency: 8-15 Hz?at
    • 10 Hz: sampling rate = 9.2 kHz and angular resolution = 0.391°
  • Communication interface: TTL UART
  • Communication speed: 256,000 bps
  • accuracy: +/- 5cm
  • resolution: 3cm
  • Weight: 105g
Scope of delivery:
  • 1 x RPLIDAR S1 360° Scanner
  • 1 x USB Interface Board (included)
  • 1 x USB to Power Adapter
  • 1 x USB to USB Mini B cable
  • 1 x Interface Cable for Sensor to USB Interface Connection
Item weight: 0,11 kg
Datasheet RPLIDAR S1
€ 799,95
