SLAMTEC RPLIDAR S2 360° Laser Scanner
  • SKU: MBS-SES-426
  • GTIN: 0618455048050
  • HAN: S2M1-R2 (30m)
  • Category: LiDAR
SLAMTEC RPLiDAR S2
  • 360° DTOF 2D laser scanner with up to 30 m range (90 % reflectivity)
  • 32,000 measurements/s, 0.1125° angular resolution, ±30 mm accuracy
  • IP65, sunlight-resistant up to 80 klx, Class 1 laser (eye-safe) – for indoor and outdoor use
The Slamtec RPLIDAR S2 is a 360° 2D laser scanner (DTOF, Direct Time-of-Flight) for navigation and large-scale mapping of commercial robots. With a measuring range of up to 30 m (at 90 % reflectivity) and 10 m for dark objects (10 % reflectivity), it is suited to use cases such as hotels, restaurants, shopping malls and office buildings.
The DTOF technology delivers consistent measuring resolution across the entire distance and reliably detects a wide range of materials – from dark surfaces to highly reflective mirrors and even transparent glass. With a sample rate of 32,000 measurements per second and an angular resolution of 0.1125°, even fine environmental details are captured.
The scanner operates reliably indoors and outdoors and is resistant to strong sunlight of up to 80 klx. The IP65 protection rating and the Class 1 (eye-safe) laser make it suitable for continuous industrial use. Thanks to its compact design (scanning optical area only 18 mm high), it is easy to integrate; via the serial interface it is pin-compatible with the RPLIDAR A series.
Model RPLIDAR S2 (S2M1-Rx)
Measuring principle DTOF (Direct Time-of-Flight), 360°
Measuring range 0.05–30 m (90 % reflectivity) / 0.05–10 m (10 % reflectivity)
Blind range 0.05 m
Sample rate 32,000 measurements/s
Scan rate (rotational speed) 10 Hz (typical)
Angular resolution 0.1125°
Scan plane flatness ±1.5°
Accuracy ±30 mm
Distance resolution 13 mm
Sunlight resistance up to 80 klx
Interface UART serial (1 Mbit/s)
Supply voltage 5 V
Power consumption > 2 W
Protection rating IP65
Laser safety Class 1 (eye-safe), infrared laser
Operating temperature -10 to 50 °C
Dimensions 77 × 77 × 38.85 mm (height 38.5 mm)
Weight 190 g
Compatibility pin-compatible with the RPLIDAR A series
  • 1× Slamtec RPLIDAR S2 laser scanner
  • Connection cable
Shipping weight: 0,43 kg
Item weight: 0,19 kg
PDF (2)
Datasheet RPLIDAR S1
Datasheet RPLIDAR S2
€ 555,95
